Old 07-04-2014, 04:40 PM
weist1013's Avatar
weist1013 weist1013 is offline
Boat: 2001 230
Send a message via Skype™ to weist1013
starter clicking
new starter, 2 monts old batteries fully charged and still getting the clicking noise, all connections are tight im running 2 batteries.. any other ideas on what i need to check?
www.reactorled.com
The After Dark Specialist
Old 07-04-2014, 04:47 PM
Boat: 93 190
John 3:16-18
Old 07-04-2014, 10:50 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
Agree with Cloaked, be sure to check the main engine ground. Also be sure that surfaces of the starter and where it mounts to the engine are clean so you can get a good ground path.
We defy the mafia!
Old 07-04-2014, 11:28 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
If all that fails take a hammer to the start and solenoid :-). Are the wires hot after the starter clicks? Kill switch fully connected? It seems every boat does something different with the kill switch disconnected
Originally Posted by Hoosier Bob
She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
Old 07-06-2014, 03:49 PM
bturner2's Avatar
bturner2 bturner2 is offline
New starter or rebuilt starter? Why was the starter replaced? Same or similar problem? If so you replaced the symptom not the source of the issue.
Low hanging fruit is going to be the cables going to the ground and hot posts. How do the cable ends look? A lot of times the cables will corrode inside the ends.
Old 07-11-2014, 08:55 AM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
The transmission should have a neutral position safety switch on it, can be a problem with the switch or the linkage. However, I'm not sure it even clicks when that keeps the starter from engaging.
Old 07-11-2014, 09:02 AM
weist1013's Avatar
Boat: 2001 230
It Must be something like that, i dont feel it is a lack of voltage, both batteries are fully charged, all connections are tight, i have inspected all terminals/connections for corrision at the connectors and where the ends are crimped on to the cables.
www.reactorled.com
Old 07-11-2014, 09:59 AM
Do you get one click or a bunch of small clicks?
Old 07-11-2014, 10:01 AM
weist1013's Avatar
Boat: 2001 230
A bunch if small clicks.
www.reactorled.com
Old 07-11-2014, 10:05 AM
Sounds like low voltage/high resistance. One solid click would suggest a bad starter. Be sure to disconnect each battery connection and clean each one, including the battery ground at the block. While they are disconnected, use an ohm meter to check resistance. I proactively found my 1 gauge positive battery cable had a very high resistance.
