Old 07-02-2014, 09:28 PM
Kdmann64 Kdmann64 is offline
Boat: 2003 Mastercraft x2
01 xstar started running rough and hard to start.
I just bought an 01 xstar has 470 hours. Ran fine on test drive. Today filled it up with 93 octane, sea foam and blue stabil, went to lake today and pulled youth group from church around on a tube. Half way through the day the boat cut off while idling, then was hard to start. It did this the rest if the day, sometimes idle was fine other times it cut off and didn't want to crank back with out giving it a lot if throttle.
Where do I start? Fuel? Carb? Plugs?
I think I want to put new plugs in what the parts store plug number ?
Old 07-02-2014, 09:57 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Your 01 doesn't have a carb. lol Why did you put all those fuel additives in there?
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 07-02-2014, 10:06 PM
Which engine do you have?
Simple first
Bad gas? Check engine light turn on?
When was fuel filter changed last? if good...
Check TPS (throttle position sensor) - connection may be loose or TPS bad.
Check MAP (Map sensor) make sure tube connected
Moving on -
Check fuel pressure - no carb either TBI or MPI fuel injection
In tank Fuel pump? pump could be failing.
Old 07-02-2014, 10:27 PM
No check engine light. I thought it had a carb, don't know why. Just looked it and appears to be EFI. Now you guys see what you set working with. Speak slow and use small words. 5.7L TBI V-DR Y2K-MC PIT/N
Model 957214
I guess it could be bad gas from the station. But it's a pretty good station. Should I run regular. Pi always put ethanol treatment in everything and when ever I buy a new boat I usually run a can of seas foam though it.
I looked around and found a vent line in the valve cover get came loose. And a plug on the I guess the main harness plugged into. Itching but can't find where it does.
Where is TPS SENSOR
OR MAP SENSOR ?
I see a fuel line on top with a black cap and fitting I assume where I can check pressure. I can do they tomorrow. No idea on fuel filter.
Old 07-02-2014, 10:37 PM
Okay let's rule out bad gas... no biggy on 93 plus additives.
TPS Sensor is on the TBI housing where fuel injectors - google GM TPS and look at images. Do the same for MAP.
If your not familiar with these components you could be chasing a lot of things down and spending $$$ for nothing.
If your not mechanically inclined get reading...
Old 07-03-2014, 07:41 AM
BG1772's Avatar
BG1772 BG1772 is offline
Boat: X-Star, 2001 5.7L LTR
If it is mainly ruining rough at idle, I would check the IAC (idle air control). If it is dirty it can stick causing the engine to run rough at idle.
Is this an LTR 330? If so the TPS and IAC are right next to each other by the air filter.
2001 X-Star 5.7l LTR
Old 07-03-2014, 09:03 AM
dcphoto dcphoto is offline
Boat: Mastercraft, X-Star, 2002, MX LTR 5.7L
Common mistake which would be the easiest possible fix - make sure the kill switch key is firmly in place and putting good pressure on the actual switch. Amateur hour for sure on that one but hey...it happens!
Principal Photographer at www.DCStanleyPhotography.com
Old 07-04-2014, 12:26 PM
Checked the kill switch it seems fine, I replaced plugs yeasterday And cranked it in the driveway. I let it run for a few minutes and it seemed to idle fine but it didn't start the other day until we had been on the lake for a few hours. I'll try to take it Sunday and try it out.
Old 07-04-2014, 03:27 PM
Boat: No Boat
Kill switch is either work or no work. It won't make hard start or poor running.
Old 07-04-2014, 08:52 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
I am surprised no one said fuel pump yet. Another place to check.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
