  #121
Old 05-11-2014, 09:35 PM
waterlogged882 waterlogged882 is online now
Boat: 93 190
John 3:16-18
Old 05-11-2014, 09:44 PM
mgs96ps mgs96ps is offline
Boat: A
Old 05-11-2014, 09:48 PM
Boat: A
Old 05-11-2014, 10:06 PM
ncsucarjock88 ncsucarjock88 is offline
Boat: 87 PS190, powerslot
This is considered a barrier and deadening material for sound. I've done extensive research on sound deadening, since bringing the sound level down in my diesel truck. (I've taken it from 99 dB down to 82dB) - that's a *huge* decrease, as the scale is logarithmic, and I'm not done. Boat will be soon to follow, I promise.
The largest problem with the boat is twofold, the barrier and deadening layers are good - the deadening layer won't do a heck of a lot for us in the boat department though, due to the lack of resonance in fiberglass, whereas in sheetmetal it is much more prone to resonate. It will help, but not greatly.
What you really need is an absorption layer in addition to the barrier, deadening, and decoupling layer. The problem is, in our boats, this is going to be a significant challenge to do without significant modifications.
MLV - mass loaded vinyl is really the missing link in the equation here to block sound, and that's what you need here - something to completely block the sound. MLV is very heavy, about 1/4" thick, and very hard to "adhere". I might experiment with some on my current engine hatch. If you could get a layer of MLV to adhere, then add a layer of Ensolite closed cell foam on top of that, that would be a relatively thin, and very effective sound absorption solution.
Here's some good reading on the actual science behind what's going on.
http://cascadeaudio.com/car_noise_control/index.htm
I actually have some of their larger engine box insulation in stock, but there isn't room inside my engine box to place it, at least on the sides, there may be enough height to put a layer on the top.
All I can say is stay tuned - probably this coming fall and winter, and I can tell you a bit more about what I've found to be effective.
I've got thousands of dollars and quite a few hours in the truck project, and it's completely worth it... I will apply what I've learned there to the boat.
Old 05-22-2014, 01:06 PM
Jordan Jordan is offline
Boat: 96 prostar
I am new to this forum but know a bit about insulation (18 years at Owens Corning). Would a 3/4" thick for pmable glueable sheet work? We make this stuff for hvac that's semi rigid, cut able, has fiberglass facing with foiled backing-- that combo provides resistance to reverb as well as Eliminates sound transfer...also has R 3-4 so will reduce thermal heat transfer...
That foam stuff in my 96 is falling off and until I read your posts I hadn't thought much about it..
Happy to send you a small sample
Old 05-22-2014, 01:18 PM
_fng_'s Avatar
_fng_ _fng_ is offline
Boat: Prostar 205
For those that have done the installation, would you say the results were worth the time and money? I don't mind the engine noise in the boat much but if it helps significantly I'm always open for little areas to tinker with on the boat.
Old 05-22-2014, 01:32 PM
Rockman's Avatar
Rockman Rockman is offline
I think it was...start to finish I think I may have put in about 8 hours or so...beers in between.
Old 05-22-2014, 02:32 PM
Table Rocker's Avatar
Rockman, were you the one who had problems with the aluminum strip inside the motor box? If so, did you get it back in shape? Did you use rivets?
'96 ProStar 205 SD LT-1
Old 05-22-2014, 03:12 PM
Boat: A
Old 05-22-2014, 03:34 PM
Originally Posted by mgs96ps View Post
On the product that I bought....don't know that I would buy it solely for acoustical performance. Of course I am the guy that rolls his window down at a stop light to hear a good V8 take off. (Also Porsches'). Those sounds never get old for me...so I have kinda trained my hear to listen to my boat when in use. Mainly bought for looks and for the wifey who wanted a quieter boat. Her first time out is this weekend...so i plan on asking her.
It looks great. Job well done.
