Old 04-18-2014, 02:47 PM
cruiser cruiser is offline
Thanks Peter, while I was waiting for carb response, I changed the shaft log hose. Coupling came right off, was totally surprised. New packing gland and the strut bearing is ok. All back together. Carb next. Thanks again guys.
1981 stars and stripes -powerslot
sand with red metalflake stripe
Old 04-19-2014, 11:12 AM
Talked to the holley guys, said the thick gasket is for heat insulation. Do not use with aluminum spacer. Which way does the upper gasket install? with the opening on the primary(front) or secondary (back) of the carb? These gaskets are not the same as original. Thanks
Old 04-19-2014, 06:05 PM
John 3:16-18
