  #4611
Old 04-16-2014, 02:06 PM
could have to something to do with relentless winter weather.. Does the St. Croix haev open water?
Pretty much, though there was some ice near Prescott, WI last weekend. the little lake near my house just had the ice go out. Couple more days and we should be done with the below freezing weather and I will be firing up the '77 for the first time this year.
Old 04-16-2014, 02:34 PM
Dynamite Spike's Avatar
Dynamite Spike Dynamite Spike is offline
Boat: 1996 Prostar 205
Originally Posted by mgs96ps View Post
I think my MCOCD is getting to me. Working on a one piece, no seam origami motor box insulation template for a 96 prostar.
This is great. Could you make the template available once you have it finalized?
Old 04-16-2014, 03:07 PM
mgs96ps mgs96ps is offline
Boat: A
DS...you are welcome to the template. No warranties on its fit. However, I am starting to think that the sheet of insulation needed to lay down the template it going to be too big and/or very expensive. It would also need some trimming along the bottom edge. All the crazy angles are hard to measure too when the engine box has radius-ed lines. Still working on it..but thinking of simplifying as well.
BTW...if you were willing to tape the four corners with a 2" strip, I think what I have will work without a hitch...but there could be variations between motor boxes of the same year.
Old 04-16-2014, 03:20 PM
I think taping the pieces together might be the way to go. Mine is also a 96 ProStar....should be a perfect fit
Old 04-16-2014, 04:16 PM
Boat: A
DS...there you go. Attached is a template 1"=1'-0". No way to plot that out on paper. You will need to transfer dimension to paper and/or cardboard. Please check it for accuracy before cutting any expensive stock.
Old 04-16-2014, 04:55 PM
Thanks mgs96ps. Was that the right file you attached?? We have a large format plotter here...I may be able to plot it out 1:1
Old 04-18-2014, 04:59 PM
Put old leaf spring back trailer. Was shipped wrong load rating. Now I need to find the correct spring. 27 inch eye to eye 1750 or 2000 pound load rating and an unloaded arc of 4 inches ... Not readily found
Old 04-18-2014, 05:16 PM
clrussell's Avatar
Mike think that it's the same around as my 90 190 had on the factory trailer? If so I replaced one of mine and it worked perfect, I can get you the part # or even a couple springs if need be.
Old 04-18-2014, 06:10 PM
part number would be awesome.. or PM me with how to order from you.
Old 04-18-2014, 11:28 PM
mcmx2 mcmx2 is offline
Boat: 2005 TT 197 #77
I looked all over for these springs when I had an 89 prostar. I found them in stock at Northern tool. I think this is them. http://www.northerntool.com/shop/too...5447_200365447
2005 197 TT #77 LQ9
