Old 03-06-2014, 09:58 PM
Jayhawk's Avatar
Jayhawk Jayhawk is offline
Boat: 2001 X-Star
Yeah, I know the MCX does. I was referring to my fellow Alabamian with his predator.
The predator has one too.
Old 03-07-2014, 06:45 AM
CantRepeat's Avatar
Boat: No Boat
Originally Posted by adrenalinteufel View Post
A stop at advance auto, an hour in the tank and a shot of starting fluid later it fired right up! Thanks for the help. I am showing only 48 psi though, is this something that will clear up once I get it in the water and run some fresh gas through it?
48 seems a little low, but I think you will be fine. The pump will pump 45 gallons per hour and I would think it's just your regulator that is keeping it at 48 psi. I would check the psi at WOT.
One thing to double check is that there are no kinks in the fuel line running from the pump to the regulator inside the tank. I believe another TT member had that issue after he changed out the pump.
All of the pumps listed are interchangeable.
http://www.autopartoo.com/oem/carter/p74122.html
http://www.autopartoo.com/oem/airtex/e2065.html
Thanks for the info!!
Tim
Old 03-07-2014, 08:31 AM
or pump about $180 per hour - +1 on the diagnosis.
Old 03-07-2014, 09:37 PM
adrenalinteufel's Avatar
adrenalinteufel adrenalinteufel is offline
Boat: mastercraft x2 2004
Thanks guys
