Old 02-01-2014, 07:28 PM
Lblack36 Lblack36 is offline
Boat: 1989 tristar 190
Unhappy 89 Tristar dash needs help
The years are starting to take their toll. The stress of bouncing on the waves have caused the penetration points of my dash to start to/completely pull through. Looking for a way to repair these. Anyone have a recommendation? I have considered laying glass down on the inside for reinforcement and I am fairly competent doing that. Just thought someone out there might have a better idea.
Thanks
Old 02-01-2014, 09:27 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Fiberglass in some fender washers that have been massaged to fit the curves.
/spôrk/
Old 02-01-2014, 09:57 PM
atihanyi atihanyi is offline
Boat: mastercraft prostar 190 1992 w/powerslot
I just did the same type of repair to a 92 prostar dash . I used a 2 part plastic "bonder" epoxy and it worked great . I added addl thickness to areas that hadn't cracked yet but were probably going to . Very happy with results . Just make sure you sand the areas first with a pretty aggressive grit
Old 02-01-2014, 11:35 PM
Thanks for the replies
Both ideas sound workable. I may incorporate both in needed areas. Thanks for the feedback. I will post photos of the progress that I make as I go and would appreciate any feedback or constructive criticism.
Thanks
Old 02-09-2014, 08:19 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
Yes
post pics I have my dash out right now also. Cleaning up the gauges
I too have some screws pulling through. Would love to see what u do. What is the dash made out of mines starting to feel brittle and has tons of micro cracks starting to form
Around mounting holes and cracking between the tac and speedo
Cheers.
Old 02-09-2014, 11:32 PM
Spork's Avatar
Boat: Sporkcraft
Originally Posted by pbgbottle View Post
Yes
Cheers.
The dash panel for a tristar is vinyl wrapped fiberglass shell.
/spôrk/
Old 02-10-2014, 11:40 AM
pbgbottle's Avatar
really ? mine doesn't really look like fiberglass it is like a molded plastic
Old 02-10-2014, 01:35 PM
Spork's Avatar
Boat: Sporkcraft
Size:  2.3 KB, hmm mine 'looked' like fiberglass when I replaced my gauges about 4 years ago, but I didn't really examine the material but I did use fiberglass resin in some fender washers to prevent the cracking.
/spôrk/
Old 02-10-2014, 09:38 PM
My dash is definitely plastic. It did have some striations that at first glance looked like strands of glass, but looking at the edges I can see that there are no fibers. That is what concerns me about using fiberglass. Never tried bonding fiberglass to plastic before......
Old 02-10-2014, 09:43 PM
tph's Avatar
tph tph is online now
I think it might be ABS plastic. Perhaps some plastic from pipe fittings and ABS glue might work.
dash, dash repair, restoration, tristar
