Old 02-01-2014, 06:54 PM
Boat: No Boat
I guess you could try and just fold them over. The tool just does the fold and curl back on both tangs at once.
The thing about the deutsch connectors is they are water tight. Where I needed to extend the pump leads I soldered and then used double shrink wrap on them.
Old 02-01-2014, 06:55 PM
Boat: No Boat
The relay box fits nicely where you have it. That's where mine is factory.
Last edited by CantRepeat; 02-01-2014 at 11:59 PM. Reason: because I don't know the difference between fights and fits!!!
Old 02-01-2014, 11:03 PM
KnoxX2's Avatar
KnoxX2 KnoxX2 is offline
Boat: 2014 MasterCraft X30
It's about time you got some work done on that boat!!!! I can't wait to ride behind it this summer.
Old 02-01-2014, 11:20 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Only if you were a Buckeye Jersey.
OH-IO!
Old 02-02-2014, 10:22 AM
bturner2 bturner2 is offline
Nice work. I'd go for the connectors. If you ever have to swap out pumps it'll be easier to do on the water.
Old 02-02-2014, 01:58 PM
JMLVMI's Avatar
JMLVMI JMLVMI is offline
Boat: 2007 X2 MCX
Very cool...love the fact you're using OEM parts. Planning on doing the same with the heater button (swapping out an ACC button) and armrest plate filler from GLS.
Old 02-02-2014, 03:49 PM
KnoxX2's Avatar
Not on your life!!!!! However I will have gas money and beer!
Old 02-18-2014, 07:57 PM
Footin's Avatar
UPS brought me a big box from WakeMakers today! Hopefully I can get some more done this weekend.
OH-IO!
Old 02-21-2014, 06:11 PM
Footin's Avatar
I have started to lay out some of the parts. I started by making a simulated mount out of a piece of scrap wood to check for clearances for the valves and thru hulls and also to verify the hole saw size. This made it easy to assemble the parts in the bilge area.
The rear valve will feed the starboard bag and the front will feed the bow bag.
OH-IO!
Old 02-21-2014, 06:15 PM
Footin's Avatar
I found something kind of interesting when I was looking at the pump mounting blocks, I was going to pre drill and screw the Johnson pumps to the transom blocks until I noticed right above the bocks are the thru hull bolted rear tie up hooks and this got me thinking.......no way would these be the same bolt pattern as the pumps??????
OH-IO!
