Old 01-10-2014, 11:19 PM
atihanyi atihanyi is offline
Boat: mastercraft prostar 190 1992 w/powerslot
That being said I get the point
Old 01-10-2014, 11:22 PM
Might be worth a compression check to rule out engine. Then again, now would be a good time to box up a prop and send it ti Eric at OJ to get it checked.
Old 01-11-2014, 01:06 PM
ahhudgins's Avatar
X2 on getting the prop checked. Meant to send mine out last winter so I'm going to pull it this weekend. It's pouring down rain but it gives me an excuse to work on the boat
Old 01-14-2014, 07:38 AM
crank crank is offline
Boat: Malibu LXI
Aaaah while you are all somewhat correct you need to look at the problem from a different view.
You have a resonant vibration issue. There are lots of vibrations happening in the boat, some are small, so much that you cannot even feel them...... What you need to do is change the resonant frequency, your prop etc may all be in tolerance, but the combination of all or some may combine at a particular frequency.
So, what to do, change the frequency, you can do this and you do do this when you throttle the engine. What you need to do is change the frequency at which the mirror resonates......remove the mirror glass from the housing and glue or attach a lead weight to one corner, maybe try two corners and use say fishing sinkers, get reasonably large ones that you can hide in the housing, do some experiments, I think you will find some success, try it.
This is a common fix on car mirrors that may suffer the same sort of vibration issue.
Regards
Old 01-14-2014, 12:05 PM
skitilldark skitilldark is offline
Boat: 2014 X-25 6.2 Ilmore
Originally Posted by ricford View Post
My guess is that there is a vibration from the drive. The whole boat is vibrating, it just shows in the mirror. Check your prop for nicks, check shaft alignment, etc.
I agree. Once on my 99 190 the mirror started vibrating badly. Ended up we had ever so slightly bent the prop on some sandy bottom. It was a very minor grounding so I didn't think anything of it. But it showed up in the mirror...
