  #51
Old 01-01-2014, 02:38 PM
snork snork is offline
Boat: 07 xstar
Removed my timers and am ready to ship, Do you still offer discounts to TT members
Old 01-01-2014, 06:35 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Hey Snork, sent you a PM.
I'm still reprogramming timers in case anyone needs a ballast timer upgrade.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 01-03-2014, 09:51 AM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
It looks like all you guys have 2007 and newer boats. I have a 2006 X15. Do I have the same type of timers for my ballast system? I am going to add 750s in the rear lockers this Spring, so just wondering what problems that I might run into if I do or don't have timers.
Old 01-03-2014, 10:04 AM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
awesome. as soon as its not -3 outside i'm going to pull mine out and send.
Old 01-06-2014, 03:38 PM
tr6coug's Avatar
As far as I know, only '07 and newer boats have the timers. The '06 boats should have a non-timed relay circuit. You can check by removing the plastic box that houses the ballast circuit breakers and looking to see if you have 3 timer boxes, or several relays.
Old 01-08-2014, 11:00 PM
imyourmaster's Avatar
Boat: 2008 X-2
Anyone know what the fill rate is on the stock Jabsco pumps? I saw an old post which indicated about 10 GPM. Another post also stated that '08 boats had timers set at 20 minutes as opposed to 6 minutes for older models.
If this is correct, the ballast pump will add 83.5 lbs of water per minute to a ballast tank (1 gallon = 8.35lbs).
My '08 X2 port and starboard tanks each add 150lbs of weight to the boat when filled to capacity. So it would take about 2 minutes to fill a tank. If I added a 750lbs bag to my port locker I would have a total of 900lbs - a fill time of just under 11 minutes.
Isn't a timer set for a 20 minute runtime overkill? I'm just thinking out loud I suppose, but it does make me wonder why you would need that much time. Please share your opinions!
Old 01-09-2014, 04:19 AM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
I think the pump is going to run slower, because of the pressure in the tank. He is filling the tank from down under so needs to pump the mass of the water up. Jabsco pump Pump Capacity: 640 GPH
Bag Fill Rate: 89 lbs/minute
Old 01-09-2014, 12:02 PM
blackhawk's Avatar
imyourmaster - The Jabsco pumps are rated at 11 GPM. I tested one in my garage with some water tubs and measured an actual one to be 10.8 GPM. Here is my original thread: http://www.mastercraft.com/teamtalk/...ad.php?t=58210
I calculated that a 500 lb tank could be filled in 5.7 minutes.
Old 01-14-2014, 06:36 PM
Boat: 2008 X-2
Thanks for the info Blackhawk!
Old 03-09-2014, 04:49 PM
Boat: 07 xstar
Re- installed Ballast Timers and everything works flawlessly, only problem is I have to turn down the stereo volume to hear when the tanks are empty
Best money spent on this X Star thus far
