Old 12-31-2013, 01:16 PM
Prider Prider is offline
Boat: 1997 Prostar 205
Carpet Whoas
I've removed the carpet in my '97 Prostar 205 and will look to replace it in the spring. Does anyone have the steps to removing the deck completely to install? What am I getting myself into? Is this even the right choice. I'm not sure how I would get room to slide it back under everything with glue etc.
Any input would be greatly appreciated.
Old 12-31-2013, 02:04 PM
Removing the entire deck would be a major undertaking.
The key is when you do get it all remove is that your lift it without flexing it. Some people here did by just gently lifting deck where it met the floor - ever so gently. There are some pics somewhere here on this forum.
I had a friend detach his deck when he redid his gas tank on his Moomba - had 7 friends lift the deck after he had it detached.
He said after removing all the fasteners - cutting the adhesive at the deck hull union.
I plan on doing by not replacing all cut out what I want to replace us as templates - dry fit and then glue down. - look in restoration thread someone is undertaking this right now.
http://www.mastercraft.com/teamtalk/...ad.php?t=56789
maybe you and PM Wingnut and ask if his installer separated deck from hull.
Old 12-31-2013, 02:37 PM
atihanyi atihanyi is offline
Boat: mastercraft prostar 190 1992 w/powerslot
removing the top cap to replace the carpet would be a huge job . I have only done this once on a smaller restoration project and wouldn't want to repeat it unless it was absolutely necessary . that being said we may be doing it on a 1980 skier of a friend of mines this summer
Old 12-31-2013, 02:41 PM
I'm never doing it again!!!... well maybe....
Old 12-31-2013, 03:59 PM
waterlogged882 waterlogged882 is online now
Boat: 93 190
John 3:16-18
Old 12-31-2013, 04:32 PM
Thanks everyone
Old 12-31-2013, 05:24 PM
uplander uplander is offline
Boat: MC 2002 X30
I would do snap in carpet
http://search.yahoo.com/r/_ylt=A0oG7...pincarpet.com/
Old 01-30-2014, 04:34 PM
Wingnut Wingnut is offline
Boat: 1998 M/C 205, 5.7 TBI
Prider- you dont have to separate the deck. However a small sissor jack or bottle jack as CLOAKED suggested is how I did it. I put a 2x4 cut to the correct length on top of the jack and under the upper corners of the deck by the dash is how I raised the decking up 1/2" enuf to get the carpet in and out from the bow portion. on the observer seat it just used a pry bar to gently lift up and slide the carpet under. then did trimming to piece together. Not the easiest but darn easier than separating the deck and hull to get at it.
