  #21
Old 06-17-2012, 04:33 PM
Jonb1822 Jonb1822 is offline
Boat: 2017 X23 6.2L
Bringing up old thread. Did anyone ever confirm what filter(s) fit 5.7?
Old 06-29-2012, 09:47 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
wix 51372
KN HP-2010
/spôrk/
Old 09-19-2012, 10:36 PM
tacoboy tacoboy is offline
Boat: 2014 X-2 7.4L and 2015 ProStar 6.2L
i have it on good authority that a KN HP-2010 oil filter is a cross reference for the Ilmor brand oil filter.
Old 09-22-2012, 12:38 PM
Red 08 Xstar Red 08 Xstar is offline
Boat: Mastercraft Xstar 08 MCX
Any of these will work:
Napa 1069
Wix 51069
Fram CPH 30 / PH 30
AC PF25
Penske PN30
Purolator L20049
Castrol CM30
Motorcraft FL10
Quaker State QS30
Old 12-31-2013, 12:13 PM
Seano Seano is offline
Boat: 2014 X30 GEN2
Napa 1069
Wix 51069
Fram CPH 30 / PH 30
AC PF25
Penske PN30
Purolator L20049
Castrol CM30
Motorcraft FL10
Quaker State QS30
Well Done
Old 03-01-2014, 11:19 PM
Scott's Avatar
Scott Scott is offline
Boat: 2012 Mastercraft X-30
in checking the marine section of k and n, its saying hp-2002 is for gm motors. has anyone verified this?? I find it odd that the black k and n is the low end of the oil filters, per there people, and thats what illmor is using and selling at a huge markup..
2003 197 tt- sold
2006 xstar- sold
2012 x-30
Old 03-03-2014, 08:55 PM
Scott's Avatar
bump, anyone?
2003 197 tt- sold
2006 xstar- sold
2012 x-30
Old 06-15-2014, 11:02 AM
bcd bcd is offline
Boat: 2014 X-2
I changed the oil in my 2014 for the first time. I unscrewed the oil filter and the filter started filling the catch pan with oil and then poured out a drain onto my transmission. Is this new? When I did the same thing to my 2012, I remember the filter not having much oil in it and the catch pan not having a drain. I just mopped up the little oil that ended up in there. I'm sure it's better to keep the filter full, just wasn't prepared for the change.
So, if you're going to remove the oil filter, make sure you stuff a catch pan under the drain hole.
Old 06-22-2014, 10:00 AM
cwarndahl's Avatar
cwarndahl cwarndahl is offline
Boat: X-45 finally better then x-10
I can verify it's not the 2002 called illmore to find out and they said they do not oem k and n, and they out out a service bulletin not to use them.
2012 MC X-25
Old 06-22-2014, 10:05 AM
its a GM 350 block.. they are saying they changed the filter fitting?
