Old 12-25-2013, 02:00 AM
Scott's Avatar
Scott Scott is offline
Boat: 2012 Mastercraft X-30
Old oil or no oil?
Boat is winterized but didn't get the oil changed and probably
Won't happen, till spring. Should I leave 50 hr oil or would it be
Better to drain and leave it empty?
2003 197 tt- sold
2006 xstar- sold
2012 x-30
Old 12-25-2013, 03:51 AM
JMann's Avatar
JMann JMann is offline
Boat: 1991 Prostar 190, Indmar 351
Send a message via Yahoo to JMann
I would just leave it but others will chime in soon.
Old 12-25-2013, 09:10 AM
Depends on how much fuel, moisture and exhaust components got into it. Draining it and either leaving it empty or refilling it won't do much for you, since the new oil wouldn't mix with or replace what's in the engine, between the parts and on all of the surfaces. THAT'S where old oil can do some damage, but 50 hours really isn't a lot of time. If the engine idles a lot, it's more important but many people have left old oil in their engines for far too long and the damage won't be catastrophic unless certain conditions are met, which probably isn't your case.
Old 12-25-2013, 10:26 AM
maxpower220 maxpower220 is offline
Boat: 1997 ProStar 205
The problem with old oil is the stuff that gets into it from running the engine, like JimN said. All of that will settle at some level in the oil and (worst case) will etch rust into the engine block or oil pan.
You are only going to leave it there for a short time (3-5 months), so I wouldn't worry about it. Just leave it until you can change the oil.
1997 PS 205
Old 12-25-2013, 10:44 AM
I wouldn't worry too much about. modern oils additive packs very good unless you have cheap oil in it. more important is fogging.... did you get to do that- or is that not needed in the 2012's.
Old 12-25-2013, 11:08 AM
fskof's Avatar
fskof fskof is offline
Boat: 2003 Prostar 209 MCX
I would leave it for now but next time change the oil when you winterize the boat in fall.
Old 12-25-2013, 06:06 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
There's no point draining the oil now. It'll take forever to drain when the engine is cold. Wait till spring, dewinterize and run it till it warms up. It'll make draining the oil much easier.
Old 12-25-2013, 06:13 PM
FourFourty's Avatar
FourFourty FourFourty is online now
The best thing to do, would be to warm it up, change it, and run for a couple minutes. That way the contaminants don't rust things over the winter. That being said, 50hr modern oil, in a modern engine, is probably not going to hurt anything. It is just not the best you could do.....
Draining is a bad idea.....
Old 12-25-2013, 10:10 PM
bsloop bsloop is offline
Boat: 91' MC 240sc
Don't sweat it. Don't make it a habit but no sweat.
First question is, why would you not take the 30 min to change the oil and filter when already there?
Old 12-26-2013, 05:31 AM
Scott's Avatar
Didn't fog, winterized myself. Dealer doesn't fog anyway..
2003 197 tt- sold
2006 xstar- sold
2012 x-30
