Old 12-23-2013, 11:45 AM
payne04 payne04 is offline
Boat: 205 v
Battery's
Have a 01 mastercraft 205v. Was wonder what battery's I would need or what to do with eletrical system for the upgraded stereo I put in.. I currently got 3 jl 300/4 slash amps and 1 500/1 ... Only have 2 battery's right now.. What do you recommend to do
Old 12-23-2013, 11:49 AM
What's the output of your alternator?
Old 12-23-2013, 01:29 PM
Boat: 205 v
Stereo
It's the stock one ...
Old 12-23-2013, 03:46 PM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
I have 2 optima yellow tops. One for the boat and one dedicated to the stereo. It's a large stereo and I haven't had any issues listening to the radio for hours.
Old 12-23-2013, 04:01 PM
MLA MLA is online now
Boat: pontoon
Are they isolated by a dual-bank battery switch? Do you regularly spend time playing the system while at anchor? The length of time this is done, is going to drive your battery selection, mainly on the "house" side of the switch. For a primary cranking battery, you cant go wrong with a plan old group-24 lead acid marine cranking battery.
For a dedicated house battery, you need to decide what your needs are going to be in terms or amp hours.
Old 12-23-2013, 05:25 PM
Boat: 205 v
Do not sit and play at all... I have to 2 battery's and they are in switch it has 2 0r 1 or all... Not real sure how to set the battery's up like you guys are talking..(house and cranking battery)
Old 12-23-2013, 06:28 PM
rydog rydog is online now
Boat: 2002 X-Star, 2008 X45 LY6
I actually was just curious about this subject. I have a 02 X-Star that will have a Syn4, Syn2, and 500 watt polk amp this next year. I currenty have 2 batteries hooked up to a perko switch so I save one for starting the boat and the other to run my audio at the sand bar. Should I upgrade to 3 batteries for this next summer? I ran 2 last summer with two Syn 4s, but now I will have the Syn4, Syn2, and polk 500 watt amp. My alternator is stock and I spend a decent amount of time at the sand bar.
Old 12-23-2013, 06:52 PM
Boat: pontoon
If your switch is wired optimal, then its already set up that way. It would be up to you as the operator to designate which one is house and which one is primary cranking.
Based on the above info, I would go with 2 group-24 dual-purpose marine batteries.
Old 12-23-2013, 06:58 PM
Boat: pontoon
Theres no yes or no answer. The need for more battery amp hours is dependent on how long you want to play and how hard you want to play. But, its always best for the batteries to have more batteries that are cycled shallower, then less batteries that are cycled deeper. If you regularly hang out at the party spot, then adding a 2nd house battery (more Ah's) could be a benefit. Then it may be time to think about some shore charging for that house bank and not rely on the alternator to recharge.
Old 12-23-2013, 07:04 PM
Would adding a third battery be too taxing on the stock alternator? Also if the 1 battery would last for a couple hours that would be fine because then I run the boat a little to charge. Would 1 battery solely used for audio last that long with my set up, estimated of course.
