Old 12-22-2013, 12:06 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Stainless bolts
Are the bolts in the exhaust risers supposed to be stainless? I removed one to clean some rust off of it to find that some of the threads are a rusted too. I would rather just replace them all with stainless if that is what they are supposed to take.
Old 12-22-2013, 08:27 AM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
Replace them with stainless; then you'll know and have peace of mind.
Old 12-22-2013, 08:35 AM
While they don't need to withstand the stresses of a head bolt, make sure the stainless bolts are hard enough and that the heads won't twist off (shear). I have used stainless screws and marveled at how frequently they broke when I was screwing them into wood, fiberglass or any other hole that wasn't too small. It may be better to use the tri-plated bolts with anti-seize.
They didn't use stainless, just steel.
Old 12-22-2013, 09:06 AM
Snipe's Avatar
Jim, I yield to a greater knowledge. I should have mentioned that the stainless will not have the tensile strength of steel. They will stretch if tightened too much. As you said though, if the torque is not required beyond a good seal, it should be fine. To be on the safe side, the anti-seize may be the better way to go. My bad. I stand corrected.
Old 12-22-2013, 09:55 AM
"Greater knowledge", meh. I just got tired of bolts and screws snapping. Steel ones last a long time, even in hostile environments, as long as they're protected.
Old 12-22-2013, 09:57 AM
MLA MLA is offline
Boat: pontoon
You can try to pick that bolt up with a magnet, that will tell you if its SS or not. For an exhaust bolt, I would use a grade-8 coated with anti-seize. Dissimilar metals will react together. This will corrode the threads and bind the bolt in the manifold. As soft as SS is, the head will likely snap before the bolt breaks loose. We see this with aluminum towers and SS hardware in the joints.
Old 12-22-2013, 10:03 AM
Boat: 93 190
John 3:16-18
Old 12-22-2013, 10:08 AM
Boat: 93 190
John 3:16-18
Old 12-22-2013, 10:24 AM
MLA MLA is offline
Boat: pontoon
For the sake of conversation, I have seen NDE techs do a MT on a 'stainless' sleeve and find flaws. Most stainless has a certain amount of carbon.
Not insinuating you are incorrect, just conversation.
Cheap imported "stainless steel" will likely be poor quality SS or even just be plated in SS. Higher quality SS may not have enough carbon steel to be picked up by a magnet.
Old 12-22-2013, 10:35 AM
Boat: 93 190
John 3:16-18
