Old 04-15-2014, 01:18 PM
81powerslot 81powerslot is offline
Boat: mastercraft 1981 deluxe power slot 351 pc
coating an aluminum fuel tank
I have an 81 mastercraft with 351 pcm. I have been having fuel delivery problems and i have narrowed it down to a fairly new fuel line already clogged (probably due to our wonderful ethanol fuel). since I have changed fuel filter, fuel pump and rebuilt the carb, and will be replacing the fuel line i need to pay attention to the fuel tank also. there is some corrosion in the aluminum tank and one of my mechanics worries that this can create debri that will damage my new components. I cannot find a replacement so i am left i think with cleaning and coating the inside of the tank. i am looking for anyone thay might have done this already and what their results were.
thank you
Old 04-15-2014, 01:21 PM
You might check with a local company that works on radiators. They may have the ability to clean and coat it for you.
Old 04-15-2014, 01:33 PM
thanks. i did that and they will clean it but they said they have never coated the inside of an aluminum tank before and wasn't sure if their coating was compatible. so i am not sure if it is even needed but there are some DIY kits that have the cleaners and coatings for aluminum tank. seems like after going through the cleaning process you might as well take one more step and coat it.
Old 04-15-2014, 01:37 PM
I will be following your lead on this as I need to do the same thing. What are they charging to clean your tank?
Old 04-15-2014, 01:51 PM
my radiator shop said they would charge somewhere around $60 to clean. but i am looking at this kit to do it all myself. seems pretty straight forward.
http://www.kbs-coatings.com/Auto-Fue...ealer-Kit.html
Old 04-15-2014, 02:02 PM
Dylan's Avatar
Dylan Dylan is offline
Boat: 15' VALCO
I used that stuff about 5 years ago on a rusty BMW motorcycle tank and it went really well. However, I thought my arms were going to fall off after shaking that solution around in a motorcycle tank.... I can only imagine a larger fuel tank!
I put an inline filter in the BMW to catch any of the debris and to this day I have yet to have any of it scale off. Follow the directions, call a buddy and get busy.
Old 04-15-2014, 02:16 PM
definitely...... wondered about all the turning but that's when you call in those ski tokens. you wanna go skiin'..... you gotta spin my tank.
actually the empty tank is pretty light but it is 48" long so i would need to make a little see-saw jig maybe to put it over and rock it back and forth. but that definitely would be the hardest aspect of the whole process i would think. but it is good to know it has lasted the test of time for you so far.
Old 04-15-2014, 02:03 PM
That looks very interesting
Old 04-15-2014, 02:11 PM
bochnak bochnak is offline
I'll have to try that product on the next tank.
I used KREEM in the past and was disappointed.
-Matt
I deal with rusty tanks on motorcycles quite a bit. I've had good results with using Caswell Epoxy tank sealer:
http://www.howtomotorcyclerepair.com...torcycle-tank/
http://www.caswellplating.com/restor...nk-sealer.html
-Matt
