Old 03-23-2014, 09:52 PM
andersonmc andersonmc is offline
Boat: 2001 X star
Wiring question
just replaced all my lights with LED's and everything works perfect. Except for my reverse lights. They never worked when I bought the trailer. Pretty sure the bulbs were toast as stuff was loose inside on the old fixtures. I'm pretty sure they turned on right when I put the truck in reverse but went out immediately. Not positive but I could of swore I saw them on. Checked plugs and ground. Where should I start?
Old 03-23-2014, 09:57 PM
Sounds like a wiring problem that is shorting out the circuit breaker for the back up light circuit. Have you checked for battery voltage at the connector with the trailer unplugged?
Old 03-23-2014, 10:22 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
May want to check your plug on the truck side. Very few trailers have backups and many time PO leaves this disconnected. You should have a flat 5 plug.
Old 03-24-2014, 10:11 AM
Boat: 2001 X star
I know my tuck is ok. I have another trailer that I use that has back up lights and they work fine. So I know its somewhere on the trailer. Should I check the plug to see if its getting power at the light? I have a feeling its shorting out somewhere on the trailer.
Old 03-24-2014, 10:33 AM
dt37803's Avatar
dt37803 dt37803 is offline
Boat: 2014 X2 5.7 Pro Surf Gen 2
If they are led the positive and negative May be reversed
Old 03-24-2014, 11:04 AM
I would disconnect both back-up lights and connect to tow vehicle to see if you have a wiring harness short to ground. Then plug in each light to see what happens.
Old 03-24-2014, 03:38 PM
Boat: 2001 X star
Just looked at flat plug. 6 wires are connected but the 2 blue are not. There is also one blue wire coming from trailer that looks to been cut.
Old 03-24-2014, 04:02 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
I think blue is the standard color for electronic brake control, but who knows how any individual trailer's been wired (or rewired)! Red is normally for the backup light.
Old 03-26-2014, 10:12 AM
Boat: 2001 X star
Well the two blue wires were aux which Wesbar says is usually for back up lights. Found the 2 blue wires way up in tongue that someone had cut. Original owner truck must have not been set up. They work great now. Thanks
Old 03-26-2014, 10:19 AM
Well played.
Email - tirespleas[email protected]
