Old 11-11-2013, 09:14 PM
mtdking mtdking is offline
Boat: 2011 X2
2011 X2 Ilmor winterization
This is my first year winterizing my boat. I decided to store it in my heated garage but still want to winterize it like it was outside just incase. I drained the Raw water, exhaust and engine block water and changed the oil/filter. I haven't added the pink marine anti freeze yet as I read that some are not good with aluminum heads. I'm confused now. I'm also not exactly sure what hose to disconnect to fill with anti freeze. There are more then a few that come off the thermostat. Any other thing that I should do? I'm all ears...
Thanks.
Old 11-12-2013, 06:48 AM
bturner2's Avatar
bturner2 bturner2 is offline
Everybody seems to have a different take on how to winterize the block but it sounds to me like you've gone the traditional way which is how I do it also. You state that you've drained the block and the exhaust. By this I'm assuming that you've disconnected the hose that runs between the two exhaust manifolds and let it drain and drained the block on both sides of the engine underneath the exhausts right? I ask because not everyone knows there are two drains for the block and draining both is critical.
Assuming you have completed both these steps correctly the next step would be to locate the large hoses just under the thermostat. One will go to the raw water pump the other to the block. You want to the one going to the block. Take the hose off at the top and start pouring marine antifreeze (I use the -60 antifreeze with corrosion protection that West Marine sells) into the hose until it start coming out the housing where you disconnected the hose from. When you see the antifreeze coming out the housing you'll know that the antifreeze has filled the block all the way to the level of the housing. Be sure to also disconnect the hose coming from the bottom of the boat to the trans cooler and clean out any debris that may be there. This will also ensure there isn't any water left in the trans cooler. I also like to pull the impeller for inspection/replacement. This will also ensure there isn't any water left in the pump to freeze. I will typically also remove the hoses going to the exhaust manifolds and pour antifreeze into to them also. This is kind of overkill as the design of the manifolds should allow for complete drainage when you disconnect the drain hose. For me though it's "better safe than sorry".
This is the procedure I've used for years on Correct Crafts, Malibus, MasterCrafts and Supras that I've worked on for myself and friends without a single incident. It's pretty straight forward and you know the block is filled when your done. I will say though that I have not worked on an Ilmor however I doubt it would be much different.
Old 11-12-2013, 08:01 AM
Boat: 2011 X2
Thanks. I think we are both in the same neck of the woods. I'm also in Brighton MI.
Here's a picture of the Ilmor engine. The Thermostat is under the air filter correct?
Old 11-12-2013, 08:34 AM
bturner2's Avatar
Hmmm where about? I'm at Maltby and Brighton Lake.
Yep the hose going to the water pump will fill the block.
Old 11-12-2013, 09:26 AM
Boat: 2011 X2
Makes sense because that is the only hose that has a standard radiator clap on it so it looks like someone took that off before.
I'm off of Silver lake road on a lake called Hidden Lake. Were just a few miles from each other.
