Old 10-21-2013, 02:27 PM
TSchimizzi TSchimizzi is offline
Boat: 1990 ProStar 190
Winterizing with bucket question?
I'm winterizing my (new to me) 1990 PS190. On previous boats I have pulled the water inlet hose at the hull and sucked the antifreeze from there. After searching this forum I see a lot of people attaching the hose at the raw water pump, bypassing the transmission cooler. I would prefer to do it this way as its easier to get at and doesn't break the seal at the hull, however I can imagine there is some water lying in the transmission cooler lines.
Which method is recommended?
Old 10-21-2013, 02:37 PM
It is best not to bypass the trans cooler. Even though you never put the trans into gear, the pump is still turning and the cooler should still be utilized. I have a 1 1/4" hose (permanently attached to the tub I use) that I connect to the trans cooler inlet. Easy to get to and effective.
Old 10-21-2013, 02:38 PM
There is no water in the trans cooler lines, just the trans cooler. The lines contain trans fluid and are sealed from the water.
Old 10-21-2013, 03:13 PM
Just make urself one of these
no more taking the hose off the hull - just the back of the trans cooler...
Old 10-21-2013, 03:28 PM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
So where exactly do you attach that Mike? Do you place that on the intake end of the pump (after removing the other end of the hose that is attached to the hull)?
Old 10-21-2013, 03:51 PM
I attach it to the rear inlet on the trans cooler. I hate taking off the hose attach to the hull.
Old 10-22-2013, 01:33 PM
bigmac bigmac is offline
MC Platinum
Boat: 2004 Maristar 230 VRS
I suspect that the transmission cooler is downstream from the pump on your boat. Attaching to the RW inlet wouldn't bypass the cooler.
As to the transmission cooler lines, there are none that contain water. Transmission oil is circulated through the cooler. The water path out of the RW pump through the cooler is just a straight 1 1/4 inch shot. The cooler is vertical...should self-drain promptly.
'04 MariStar 230VRS/MCX
Old 10-22-2013, 06:55 PM
soacj's Avatar
soacj soacj is offline
Boat: Current: '03 X2 w/ MCX. Former: '91 Prostar
Raw water inlet feeds the trans cooler (does a fine job filtering out debris...) and then goes to the pump.
Old 10-23-2013, 12:22 PM
MC Platinum
I guess those things were set up differently on those older MasterCrafts.
Old 10-22-2013, 01:49 PM
bochnak bochnak is offline
If the trans is in neutral, it is not going to generate enough heat to need that cooler hooked up. You can verify by grabbing the cooler from time to time to monitor temp.
If you are running for an extended period of time, then yes, I would hook it up to cooler.
-Matt
