Old 08-26-2013, 09:56 PM
JaredOSU JaredOSU is offline
Boat: Mastercraft Prostar 190 351 Windsor 1:1 Borg Warner
rub rail
I have a 1989 Prostar. my rub rail needs replaced. Where can I find a replacement?
Old 08-26-2013, 10:07 PM
Tacomarine http://tacomarine.com/
Old 08-27-2013, 03:44 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
I removed and replaced my rub rail last year and went with Taco marine products as well. I replaced BOTH the rub tail and the insert as well, so that is a consideration. Go on their website, or someone who sells their product, (Rex Marine, I believe) and try to match the shape/style of the insert (very important, boat model specific) and then request one or multiple samples of the style/color you want to make sure it will conform to your hull's curve lines. Won't cost you a thing and gives you piece of mind before you buy 50' of rail and insert and have it shipped in a big coil....
Old 08-30-2013, 09:19 AM
Skir68 Skir68 is offline
Boat: MasterCraft, '83 S&S Powerslot, Red Metalflake!
I replaced the rubber insert on our 87' Prostar last year. I found a local shop Eagle Mouldings.
http://www.eagle-aluminum.com/Rub-Rail-Vinyl_c_91.html
They had the correct insert in stock! They just unrolled 50' plus a couple extra, and I was out the door!
Old 08-30-2013, 09:25 AM
Thanks for posting the link. Replacement for mine is coming close to the top of the to do list.
Old 08-30-2013, 02:55 PM
Your Welcome! It's only 2 blocks from my office. If you bring a small piece with you, they will make sure to match it exactly. They even gave me some helpful hints to get the new stuff inserted! (not an easy task)!
Let me know, when your ready, I will help you install it!
Old 08-30-2013, 02:56 PM
Much appreciated. I haven't looked yet, but do they sell the aluminum channel as well?
Old 08-30-2013, 09:39 PM
YEP! They sure do! I thought about changing mine on the 87' I saw an 83' Nautique with a rope inside the aluminum channel,(VERY CLASSIC OLD SCHOOL) a teal rope would look sweet with the teal stripes on my boat. I didn't want to spend the time drilling the entire channel out and redrilling and riveting the new channel on!
Old 09-08-2013, 12:32 PM
I have another couple of questions...
How hard is it to replace the carpet?
And when I put the new aluminum rub rail on, can I not just use the existing rivet holes and maybe use a larger rivet?
Old 09-13-2013, 05:52 PM
Hi Jared, I don't know about carpeting, but as far as the new rail goes, I drilled new holes, just because its not easy to see the old holes because you are covering them up with new rail! Make sense? I got a cheap rivet gun and 3/16 rivets and went to town. It was kinda fun after awhile drill hole, insert rivet and "pop" them tight! I just figured out a pattern so I didn't accidently drill into any existing holes.
Hope this helps you!
