Old 08-12-2013, 10:52 AM
Boostd_GSXR Boostd_GSXR is offline
Boat: 2006 X-30
Where do you leak?
It seems like I'm taking on water this year. I'm running the billage more often than normal. In the past years I would run the billage at the end of the day to get out the water that the skiers drug in, this year I am needing to run it about three times through out the day. Are there common areas for Mastercrafts to develop small leaks? Obviously I went through and checked the drain plugs already. Outside of that I haven't looked to deep yet. I plan on getting into it and starting to try and trace out leaks this week or next week. This is on my 06 X-30
Old 08-12-2013, 10:57 AM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
Id check all Bilge lines for leaks and fat sacks for pin holes
Old 08-12-2013, 10:59 AM
92 190 PS's Avatar
92 190 PS 92 190 PS is offline
Boat: 2008 197
Most likely coming from the shaft packing if you've checked all of the other common areas. You can tighten slightly if you have never done so, but be sure there is still some dripping (once every 10 seconds or so). Replacing the packing is very simple and if you have not done so in the past it may be time. Good news is if this is your issue, it is a simple inexpensive fix. Good luck.
http://www.skidim.com/prodinfo.asp?number=GFO3/16X24
Ha..I take back how simple it is, I've always had direct drives. Looks like v-drives are a bit more fun.
http://www.mastercraft.com/teamtalk/...+shaft+packing
2008 Prostar 197
Old 08-12-2013, 11:01 AM
bjames's Avatar
bjames bjames is offline
Boat: 2009 X-Star LY6
I assume the water is not from taking water over the bow or transom. Also check all your water cooling hoses. Make sure the clamps are nice and tight.
Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. c/w 1/9 scale R/C PWT X-Star
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2009 Moomba Outback V
2008 Monterey FS180
Pelican 4 set paddle boat
plastic tug boat when I was 4
Old 08-12-2013, 11:18 AM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
mine is leaking from the rudder port quite badly
Old 09-25-2013, 09:38 AM
craig3972's Avatar
I put an o-ring between the the top of the steering arm that attaches to the rudder shaft and the rudder port seal to force the grease down into the rudder port. I made sure that the grease encapsulated the circumferance of the rudder shaft in the rudder port. I kept pumping grease into the port until grease was coming out the bottom (water side) of the port. no more leak.
I boat shop owner told me he has seen rudder shafts that have worn out due to lack of grease in the port.
Inventors; there is a product here. jamming grease into a hole to plug a leak is low tech.
Old 08-12-2013, 11:27 AM
Guest
I usually leak while I am waiting for my driver to pull me up, or i find a nice tree
Old 08-12-2013, 11:41 AM
sp00ky's Avatar
sp00ky sp00ky is offline
Boat: 1994 prostar 205
I had to change the raw water pump seal this year which was leaking more than I realized. Since then my bilge has been quite dry. unless I get rained on which has been WAY TOO
often this year bilge pump rarely runs.
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
Old 08-12-2013, 11:46 AM
dsword dsword is offline
Rudder port is the place I have seen water come in in the newer(2005 and up) boats.
David Sword
Old 08-12-2013, 02:54 PM
timvan's Avatar
timvan timvan is offline
Boat: none
Originally Posted by sp00ky View Post
d. unless I get rained on which has been WAY TOO often this year bilge pump rarely runs.
+1
My boat is still drying out from this past Saturday.. What a wake that extra ballast throws!
2002 Maristar 230 VRS
