Old 06-03-2013, 12:11 PM
Hatch7 Hatch7 is offline
Boat: 1993 Prostar 190
Fuel Question
First time out was Memorial Day weekend the boat (93 Prostar with std 351) ran great. When I winterized I had filled the tank with 93 octane. As the weekend progressed new fuel was added which I found later to be 87 octane. After the refill she started sputtering when dropping the throttle at the hole shot. The boat now has a full tank of the cheap stuff. The question is: Does anyone have any experience with adding octane boosters? Would it be recommended or not? I'm sure it could be something else but fuel seems to be the likely culprit since she ran great out of the gate.
Thanks,
Hatch
Old 06-03-2013, 12:32 PM
Boat: No Boat
Thanks,
Hatch
They are all snake oil and not worth your money.
Unless someone has done a lot of work on that engine you are kind of wasting your money running 93.
Did you put any kind of fuel stabilizer in when you winterized?
Old 06-03-2013, 03:51 PM
I have heard mixed reviews on the additives but most are in the snake oil camp. What about Marvel Mystery Oil? I know nothing about it's composition but could that help or hurt?
I do use Stabil on a regular basis both during the season and the appropriate amount for winterization.
Old 06-03-2013, 12:50 PM
SP Maristar's Avatar
I used to use it on my Porsche 944 Turbo and it really helped smooth out the motor. It is already a fantastic motor design with counter rotating balance shafts, but the higher octane with the turbo made it even better. Not sure how much a non turbo motor would benefit.
Old 06-03-2013, 12:56 PM
Table Rocker's Avatar
Was is sputtering or pinging/detonating? Lower octane causes detonation in higher compression engines.
Where did you get the gas that you later found to be 87? Could it have been old gas? Gas that sat in a can for a while, gas that sat in a marina's tank over the winter?
'96 ProStar 205 SD LT-1
Old 06-03-2013, 03:55 PM
I usually make it a practice to use all the gas before we leave or fill all the equipment and boats etc and add stabil but some could have been left and inadvertantly used. Fortunately for my wallet we go avoid the marina fuel.
Old 06-03-2013, 04:23 PM
Someone went out to pick up the gas so if there was old gas in one of the tanks we use or condensation it could have caused the problem.
There was no sputtering or pinging just the delay and some coughing. As long as I go slow at the start it doesn't seem to happen.
Old 06-03-2013, 01:00 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Run 89 in that motor as recommended in the manual and keep it stabilized (even during the season unless you are burning through a tank every two weeks). You could siphon off the gas and use it in cars or lawn equipment or you could add some 93 back to whatever is left of the 87.
2 parts 87 to 1 part 93 = 89.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 06-03-2013, 01:33 PM
Boat: No Boat
Doug,
Everything I've read says 87 for 351w/302 and that's all I ever ran in my 92. I guess it's just a matter of how long it sits before use and whether or not that it was stabilized.
Old 06-03-2013, 03:15 PM
I use 87 with no issue. I do not use additives of any kind.
carburetor, fuel problem
