1990 Prostar 190 / Ford/Indmar 351w GT40P:
length : 19' 0" = 5.79 m width : 80" =2.032 m weight w/o fuel:2.200 lbs = 998 kg fuel capacity: 25 gall = 94.6 l engine oil: sae 30 /api sf 4-3/4 quarts = 4.5 l 10w30 transmission oil: dexron ii or iii 2quarts = 1.89 l (any type except f) firing order: 1-3-7-2-6-5-4-8 spark plugs (for gt40 heads not stock E7's): btfm3m /.035" hotter awsf52c 106 / 766 / 606 hot awsf42c awsf42c-6 765 / 5245 605 stock awsf32c 104 / 764 / 5144 / 5164 cold awsf22c 103 / 5143 / 5243 bosch super - 7580 (hr9dcy) autolite - 764 (ap764 for plat, app764 for double plat) champion - 401 (rs14yc6) motorcraft awsf32c ngk standard bpr6efs Modifications: http://www.latemodelrestoration.com/ gt40p heads (best improvement along with the prop) LTP-66879 roller rocker arms, aluminum, 1.6 ratio, 3/8 stud mount, small block ford, set of 16 x1 http://www.skidim.com/ rk122014 starter kit lh 302/351 permanent magnet edl-2181 intake manifold performer 351 w rn0120-1 renew kit 4160 holley, 351, 350, 5.8 rp173072 breakerless ignition kit 87 up (huge improvement, no more points, remove resistor) r117004 coil ignition electronic 427204 telssc6117 safe-t steering cable only 15’ (apparently some prostars that year use 17') http://www.summitracing.com/ CCA-CL35-242-3 cam & lifter kit, xtreme energy , hydraulic flat tappet, 351w, 224/230 duration, .510"/.512" lift x1 (haven't put it in) PRO-302-001 proform ford racing licensed aluminum valve covers 302-001 (need spacer exhaust manifolds to create a bit more space) pro-67235 adj vac secondary housing (nice if you want to be able to adjust sencondaries on the fly) ult-9014-045 optima yellowtop deep cycle 12 volt batteries 9014-045 SPW-1450300 Superwinch S Series Winches 1450300 (got tired of winching) http://www.fordracingparts.com/ m-9600-l302 round air cleaner assembly http://www.overtons.com item 74334 sahara 6 gauge set http://www.perfectpass.com/ perfect pass stargazer for carbureted applications (wife drives through the course) http://www.nettleprops.com/ Acme 541 Propeller 3 Blade 13 X 12 LH 1" (best improvement along with the heads) http://www.amazon.com/ Lokar XED-5005 Black Stainless Steel Housing Dipstick with Black Fittings for Ford 351 Engine (nice and flexible) Last edited by Wouter; 05-03-2013 at 04:11 PM. |
Wow, wish there was more like this post. Great note taking.
Impressive list.
Are you using an automotive air cleaner in place of a flame arrestor? http://www.fordracingparts.com/ m-9600-l302 round air cleaner assembly
hum, yes, good eye, I am using an air cleaner in place of flame arrestor (those things look so wimpy...)
Are you using the K&N flame arrestor element with this?
nope; just the air filter that came with the ford racing assembly. Motor box doesn't have insulation and gives just enough clearance (if that's why you are asking)
It's been on there for a while now but you're absolutely right... good catch, hadn't occurred to me
pix of the stang? Last edited by Wouter; 05-03-2013 at 12:30 PM. |
Any pics of the engine with the air cleaner? I would think that with an approved filter it would be acceptable to the Coast Guard.
I see. Not coastguard approved unless it's the K&N Marine Approved per SAE J1928 Flame Arrestor Standard... No USCG over here: wonder if that's riskier in case of backfire? Myabe time to get the K&N one...
interesting link: http://www.knfilters.com/marine/flamearrester.htm |
Thread Tools | |
Display Modes | |
