Old 04-25-2013, 11:33 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
As mentioned in my other thread :
http://www.mastercraft.com/teamtalk/...ad.php?t=53645
After changing the ATF fuid of my velvet drive 71c (model 10-17-004) (which had probably never been changed) the transmission started slipping severely. I decided, it was time for a rebuild, so here goes the write-up:
Tools/fluids/parts you’ll need:
- Dexron III ATF oil (preferably mineral)
- WD40 / engine cleaner
- Rebuild kit (includes forward and reverse clutch plates, seals and gaskets) http://bpi.ebasicpower.com/p/ALT23901
- Complete snap ring set or at least front bearing snap ring:
http://bpi.ebasicpower.com/p/ALT23255
- Possibly a new damper plate:
http://bpi.ebasicpower.com/p/ALTDA-106A/
(All these parts are also available elsewhere (i.e. skidim.) I have no affiliation with ebasic.
- An arbor press (mainly to compress the clutch pack)
- Snap ring pliers
- Rubber mallet (came in very handy)
- The usual assortment of torque wrench(es), socket (hex but also at least one 3/8" 12 points socket), etc.
- One big (38mm) 1-1/2” hex socket
- A feeler gauge 0.018" to 0.055" (to set clutch clearance)
- Shop or service manuals:
http://www.mastercraft.com/teamtalk/...ad.php?t=32581
different manual attached to this post. look below transmission tag.
Important things to remember:
This thread does not cover reduction ratios.
Stage the parts in order as you are pulling them out to remember how they go back in.
If you can, take pictures as you go in case you forget how/when a particular part came out.
Make sure to note position of pump housing (this is particular to your engine’s rotation direction.)
Read service manual and thread completely before starting
File Type: pdf Borg-Warner-Velvet-Drive-71C-72C-Transmission-Owners-Manual_red.pdf (1.49 MB, 4582 views)
Old 04-25-2013, 11:46 AM
Wouter's Avatar
Bellow is a diagram of the velvet drive: I'll use the diagram part numbers for the rest of the thread:
Old 04-25-2013, 11:47 AM
Wouter's Avatar
remove transmission from boat and note position of pump housing.
Old 04-25-2013, 11:50 AM
Wouter's Avatar
remove pump housing 104
Old 04-25-2013, 11:55 AM
Wouter's Avatar
remove pump drive gear 101 (slides off)
remove woordruff key 65 from drive gear assembly 64
Old 04-25-2013, 12:00 PM
Wouter's Avatar
remove 99 (12 points (10mm) 3/8" socket necessary)
Old 04-25-2013, 05:02 PM
catamount catamount is offline
Boat: 1987 ProStar 190
I may need this thread in the future, so I just wanted to say thank you!
Old 04-25-2013, 07:56 PM
CantRepeat's Avatar
Boat: No Boat
Great thread! This site has needed this for a long long time. It will show people that rebuilding these velvets are within the grasp of the normal shade tree.
Once you post up the reassembly this should be cleaned up and added to the FAQ for sure. Once all the photos and such from the reassemble we can all add our 2¢ and links to tech manuals and what not.
Tim
Old 04-26-2013, 09:05 AM
Wouter's Avatar
Next step will be to repair small leaks in muffler with fiberglass and puting muffler and tranny back in the boat. I don't think I will replace the damper plate in the end: it looked good as is on first inspection.
Old 04-26-2013, 09:38 AM
bstewart0529 bstewart0529 is offline
Boat: 1991 prostar 190
I can not say thank you enough. this will be helpful in the future for me i am sure. thanks for taking the time this was fantastic.
