Old 04-17-2013, 02:13 PM
87 TriStar 190 87 TriStar 190 is offline
Speedo reacts slow
The VRO speedometer is very slow to react. Takes a while to get a reading, and then it's slow for quite a while. Will eventually get up near slolom speed, but for pulling swivel (my daughter) and wakeboards, it's about useless. I have taken off the pickup and blown air through to clean that out. Stuck a wire through it also. Seems clear. I understand that inside the boat, there is a damping tube that may have water in, or be causing a problem. Does anyone know where that is in an 87 TriStar 190? Anyone ever had this problem before? I have been using a handheld GPS for the past few seasons.
Old 04-17-2013, 02:21 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The dampen tubes are located behind both side storage boxes on either side of battery compartment. Remove storage boxes for access.
/spôrk/
Old 04-17-2013, 05:54 PM
3ponds 3ponds is offline
Boat: 1993 PS 205
Take the tubing off the back of you speedometer and disconnect the tubing off your pitots, then blow thru the line with an air compressor from the speedo end. The line probably has water and slimey crud in it. This has worked for me on a couple of boats I have owned.
Old 04-21-2013, 09:56 PM
I've tried to take the tube off the speedo but can't get my hand in at a good angle to remove it. There's a hole in the dash for another gauge and I can take that out, but can't manipulate in that space. That's why I wanted to try from the dampers. Will be getting the boat hme the end of this week from storage and I'll try it. What air pressure do you use? Don't want to fail a line.
The boat only has one speedo. Really would like it working perfectly again.
Thanks for your help. Will keep you posted.
Old 04-22-2013, 01:31 PM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
My Tristar has a carpeted panel under the dash that you can take out with 4 screws (I think) and have access underneath to anything.
Old 04-22-2013, 01:41 PM
I have the carpeted panel, but when that's off, there's a fiberglass molded enclosure around the instrument pod. Can't get at anything from under there except the stereo. Might be able to remove the smaller panel that the ignition is mounted to, but not sure I could get my hand in there either. It's pretty tight because of all the wires. I do like the idea of blowing it out from the gauge position. Is there anything in the damping device I could damage with high pressure air?
Old 04-23-2013, 10:04 AM
Spork's Avatar
Boat: Sporkcraft
You will need to remove the steering wheel that gives you access to remove the dash panel, only way to get enough room to remove the gauges.
/spôrk/
Old 04-23-2013, 01:41 PM
Never removed the steering wheel before. That sounds like a brutal task. I think the first approach should be to disconnect at the inlet of the damper and blow through that and out the line to the pitot tube. Will disconnect the pitot prior to inducing air.
I don't have storage boxes in the back, only a single panel that raises upward on a hinge for battery access. The battery sits in a tray. The only access is when the rear seat is out, there is a gap between three and four inches you can see under. If I remember correctly, the floor carpet goes up the back under there. No idea how to gain access to anything under the floor except in the middle where a floor panel lifts for rudder lube etc.
Plan to get the boat out of storage this weekend so I'll study it. Will take pictures if I don't see an easy way in.
Thanks for your suggestions. Together, we'll figure this out. Really would like to have it working properly again.
As my dealer says, "Remember, it's a MasterCraft. It's always something simple".
Old 04-25-2013, 10:14 AM
Miss Rita's Avatar
Somehow you'll have to remove the backrest(s) to get to the equalizers that dampen the speedometer movement. (I think they're called equalizers). They're brass tubes with very tiny holes that work to dampen movement of the speedometer needle in rough conditions, not unlike a shock absorber on a car. You could easily bypass them and not notice any difference.
Old 04-30-2013, 01:46 PM
Brought the boat home from storage last weekend so I can look at things. I need to take a few photos and post those so you can see my challenges. I removed the center cap covering a blank hole in the dash directly above the steering wheel. Can reach in, but only enough to remove one nut holding the speedo in place. Can't reach the second nut. The tube fits in the center of the bracket holding the speedo in place and I can't get that off. There is only about a 2 to 2 1/2 in hole behind the gauges where all the wires and the speedo tube come through. Not enough space that if I took off the carpeted trim under the console that I could get a it.
Also looked at the back to find the equalizer and that is pretty much sealed off. The battery sits in a tray that I might be able to remove, except the flexible blower tube runs through a hole cut in the tray. The equalizer should be accessible shouldn't it? Is it typically located close to where the hose comes through the boat at the pitot pickup?
Will take photos and post. Thanks again for your help.
