Old 03-19-2013, 02:02 PM
Beg4wake Beg4wake is offline
Boat: 2008 Mastercraft X-Star, 400hp Vortec
Quick help, LATE OFF SEASON WINTERIZING
Quick help....I just bought my Mastercraft from a dealer that kept the boat in a heated facility therefor they did not fully winterize it (i.e. no antifreeze through coolant system. Here in VA we only have a couple weeks of cold weather left. However over the next few nights it is supposed to get down into the mid to upper 20's. I would have to leave work early today in order to get it done...but should I go ahead and drain the block and run antifreeze through the boat just in case?? Or would I be fine....
Old 03-19-2013, 02:05 PM
Id def do it!!!!!! check winterization forum for process
I would pull all the plugs and hoses to get the water out and perhaps put a heater or trouble light under the engine cover. I don't think you need to go the antifreeze route if your temps are only going down to the mid to upper 20's. What are the high temps you are looking at?
Old 03-19-2013, 02:09 PM
It's in the 50's today
Old 03-19-2013, 02:12 PM
I wouldn't rush hoe to deal with this, but I would drain the water out. You could probably get away with just a heat source under the engine cover, but it is simple enough to drain it down. Definitely no need to use the antifreeze. Pay attention to get the water out of shower or heater is you have either.
Old 03-19-2013, 02:11 PM
Ski-me's Avatar
Ski-me Ski-me is offline
2008 X-Star....
I'd at least drain the block and disconnect the hoses. Look for the heater hoses/shower hoses too, if you have them.
You can at minimum place a lamp in the engine compartment to keep things warm or possibly a heater (just be careful not to light it on fire!).....
- Jeff
1994 205, LT1
antifreeze really isn't that hard. Just pull the hose off the bottom of the RWP, clamp it around my clear hose section, stick that in a bucket of antifreeze and start the engine. I'm coming from a Moomba though and I'm not 100% sure where all the drain points are on this specific boat or what it takes to to it all. The Moomba had 2 plugs in the bottom of the block that the knock sensors hooked to for the main drains....is that about the same on this boat? (plus hoses)
Old 03-19-2013, 02:14 PM
Ski-me's Avatar
I think you need to let the boat warm up to operating temp in order for the t-stat to open and allow circulation throughout the entire engine....
- Jeff
1994 205, LT1
Old 03-19-2013, 03:20 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Two plugs in the block (one each side), and disconnect the hose that runs between the manifolds/risers.
Old 03-19-2013, 04:45 PM
Jerseydave's Avatar
TT Hero
One side of the engine will likely have a knock sensor not a plug, just remove that and make sure water pours out of both sides of the block. Disconnect hose as stated above. You should pull the impeller after cranking the engine over to drain water from that area as well.
Where are you in VA, Lake Anna?
Nice boat.....Welcome to the X-star club!
I was njskier on here.
