Prop Strut Alignment
Today I was putting in a new steering cable in my 01 X30 and when aligning the steering wheel I noticed the rudder was about 1" to the left of the center of the prop shaft when looking from the rear. I had my buddy who is a long time Malibu mechanic look at it and said that usually means a bent prop strut. After doing some research on here I came accross a thread that said that the rudders are usually offset about 3/4 to 1" to the port side. Is this true?
The prop strut doesnt look bent, there are no vibrations to speak of while driving and there is no damage to the prop strut. I bought the boat used and have never hit anything with it. Would just like to get some input on the rudder alignment before I go looking for a new prop strut. |
The rudder is offset to the left to be able to change the props easier if im remembering correctly.
2010 X15 Surf Tabs, 4 wet sounds pro 80's , heater, underwater lights and the mcx! |
But what you've noticed is perfectly normal for a Mastercraft.
1998 Maristar 200VRS |
I was close! haha
KEEP reading----your both wrong!!
You haven't lived until you grab a wild hog by the legs when a dog is holding him by the ear!! |
It's offset to counter act the torque of the prop to the port side and as a result you get to change the prop easier...
/frank
Look up "p-factor" in single engine aircraft---Same principal applies to fixed shaft and rudder on a boat----
And that info is in books----not just the "Internet"!!
Wow,"P-factor", "step on the ball! , step on the ball!" it's all comming back now.
