Anyone hooked up to a private gas well for house gas? Need some advice.
I am in the process of building our new home and we are connected to a private gas well that is located on the property for our gas supply. The gasline from the well to the house is roughly 500' of 1" line and we have 40lbs. of pressure at the well head. When the gas comes off the well head it goes into a lil joe regulator that is set at 12lbs. then over to a drip tank and the meter before making the 500' run to the house where we have a gray pancake regulator it passes thru and the into the house.
So, my problem is that the safety valve or plunger on the pancake regulator trips at some point during the day or night shutting the gas off and I am not knowledgable enough in this area to figure out why so I turn to you guys. I was told by the guy who services the well that my house may be drawing more than the well can produce but somehow that just does not make sense in that if I have 40lbs at the wellhead and am turning that down to 12lbs before it hits the house regulator, I should have plenty....right? I am not sure at what point the gas is actually turning off as I am not there to see it but I do know that when I pull the little plunger pin back out on the pancake, the gas flows just fine all day? Any ideas? |
You may have 40lbs some of the time, but not necessarily all of the time.
Post some pictures and more details on the regulator and just what is popping.
Whats the gas pressure after the 500' run?
The pressure after the run is being controlled by the pancake regulator at the house and it comes pre-set from the factory. From what I have learned it typically gets reduced to ounces once it passes thru the pancake as that is what the furnace and various appliances require.
The plunger that keeps popping, from what I have learned, does so when the gas supply drops. This is a safety feature to prevent gas from free flowing into the house to any appliances that have a pilot, so that when the gas comes back on, it can not just fill the house with gas. With 40lbs at the well-head and the natural loss/pressure decrease that takes place as it travels, I can see where it is possible that the well is simply not pushing enough to replenish the line in enough time to keep the pressure up and the plunger from being sucked-in/shutting the gas off. The other possibility is that the regulator has moisture in it and is freezing with the temp fluctuations we have been having, so I will likely try to take it off this weekend and pour alcohol into it to at least eliminate that variable. In addition, I think I will pickup a pressure gauge and put it inline at the house before the line enters the pancake to see what my decrease is over the 500' run. It may not be a bad idea to add yet another gauge after the pancake to see what I have just before it enters the house. The end solution to this may likely be to connect to the local gas supplier as a backup source and install a valve that allows the backup supply to flow when the well gas shuts off. The problem I see with this is that I will not know when this takes place so I could end up running on the backup source far more than I need to. Anyone have any experience with this type of setup? |
CP
1998 ProStar 190 30th Anniversary, Corvette LT-1, STARS AND STRIPES BABY (with a really bad bimini)!!!!!!** * Footin' anyone?RON PAUL FOR PRESIDENT "May future generations look back on our work and say that these were men and women who, in a momnet of great crisis, stood up to their politicians, the opinion-makers, and the establishment, and saved their country." - Ron Paul |
Thanks CP.
For what it is worth, I just spoke with the contractor who has been out at the site everyday and the last time he had to pull the plunger back out was on Tuesday morning, otherwise it has been running just fine since then without the gas shutting off. We have not changed anything, the outside temp has been a little more consistent but otherwise no variable have changed. |
jk, the guy at work said that you may need to get a 'little-joe'. He said what is happening is at the well head where the pressure goes from 40 down to 12 there is an orifice and when the weather changes moisture builds up inside the line and freezes which cuts your gas and causes the pancake valve to close at the house because of the pressure loss. He said the 'little-joe' is a heater that you put on to keep the line warm and prevent condensation at the pressure change location. He said they are around $100-$120. He also said if there is already one installed on the line, it may need to be 'activated' which you do with a battery.
I'm no expert, but this is what he had to do and he said when the weather changed temperatures sometimes he would have to go out several times a night to keep it going. After he installed the 'joe' his problem was solved. Hope this helps. If it doesn't, I'm sending in the punter.
Fisher Little Joe Regulator.
We deal mainly with the big pipe and gas transmissions but nothing down to residental. I've heard of Big Joe's but not Little Joe's. Anyways, here is an example of one but it looks REAL small. Like, for a BBQ but same concept I believe. Mainline pressure can range from 500psi to 1,000psi....just depends on the gas line. Getting free gas is an amazing deal so I'm quite envious! Hope this helps!
- Jeff 1994 205, LT1 |
Thanks guys. I have not had a chance to take photo's yet but we do indeed have a Little Joe in place which is regulating the gas pressure from 40 down to 12. That being said, I have been told aboutthe condensation issue and it has been suggested that I remove the little joe, pour some alcohol into it and then empty it out to clean out any possible condensation. I am a little reluctant to do this right now since the gas has been flowing without issue for a few days (don't mess with it if it is working!). I will have to look into the battery heater as I think that would be a better long-term solution.
Thanks for the advice guys, it is much appreciated and I will post some pics of the set-up tomorrow. |
#10
When was the last time the well was bailed,it should be done every year,thats why it`s freezing up.
