Old 01-27-2013, 08:40 PM
h2oskifreak's Avatar
h2oskifreak h2oskifreak is offline
Boat: 1975 Mastercraft Stars & Stripes
Shower attachment
My 94 PS 190 came to me a year ago with a hot water shower. When it was winterized the gentleman said he could not guarantee he got the HW shower pump to fill w/ antifreeze and sugested I remove it. I did remove it and am toying with not putting it back in, but also might do so if I had the attachment. It leaked a little rusty water in the gunnel in the past but it cleaned up. It has a quick release hose but I see nothing anywhere on the unit that notates a model or maker. What are the best shower attachments and what else should I know before I go one direction or the other?
Old 01-27-2013, 09:55 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
By attachment, do you mean the shower head? Are you sure the pump works? If the pump worked, he should have been able to turn it on until antifreeze came out of the hose. My 96 came to me 2 years ago with a shower, but the pump does not work. I was going to replace it, but the cost of the pump was prohibitive, and in the last 2 years I have not really had a time when I wished I had it.
Old 01-28-2013, 12:16 AM
I think the pump works but w/o the shower head to allow flow he was having trouble. It is a quick connect coupler type at the end of the hose and it came w/ no attachment for length or a shower head.
Old 01-28-2013, 09:25 PM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
Here is a good company (Bakes online) that sells the replacement parts at good prices and has a 10% off code. Just enter shower in the search window and the next page has the replacement parts you are after.
http://www.bakesonline.com/default.aspx
Old 01-28-2013, 07:11 PM
snork snork is offline
Boat: 07 xstar
most likely Heater Craft
Old 01-28-2013, 07:49 PM
jakethebt's Avatar
jakethebt jakethebt is offline
Boat: '96 Prostar 205 LT-1
I'm not sure if this helps or not, but this is probably the manual.
1996 Prostar 205 LT-1
Old 01-28-2013, 09:50 PM
dfski dfski is offline
Boat: 1992 ProStar 205
Sorry I can't help with your question but I have been considering adding a shower to my 92 PS205 and was wondering where to mount the pump. Can you tell me where yours is mounted and maybe share some pictures. Also the temperature controls. Thanks
Old 01-29-2013, 09:23 AM
Mine is mounted near the front corner of the gas tank just behind the transom carperted cover and the hose leads to the side storage gunnel. The temp. control is under the engine cover, just mounted to the deck, close to the gas shock mount. Thanks for the info and links guys, I think I will reinstall and have it available for use.
