2013 Towboat Evaluations
Just looking at the Towboat evaluations in this months Waterskier Magazine. Anyone know why they refer to the 190/197 as unmodified? What would the modifications be? Engine? Hull? Both?
AWSA considers a boat to be modified if any of the following occur.
"New or Modified Towboat A towboat model tested at the preceding year's towboat test will be considered "new or modified" when any of the following conditions are met: 1. Non Propulsion System Related Items (a) The towboat hull / plug has been changed or modified in any way from the gunnel downward. This includes changes to spray rails, strakes, etc. This also includes a change in the size or location of the stability fins or shaft location. (b) A change is made from a closed deck to an open bow, or vice versa. (c) There is a change in engine placement or location. (d) A change in speed control software or hardware that impacts the skiers’ pull in slalom, trick or jump. (e) There is a change in total weight of more than 10%. (f) Any other changes must be approved by the AWSA Towboat Committee prior to the boat tests. 2. Propulsion System Related Items (a) There is a change in the engine manufacturer or model as tested from the previous year. This includes cubic inch displacement, horsepower, carburetion/EFI, engine management system (ECM), etc. (b) There is a change in transmission gearing (e.g., 1:1, 1.25:1, 1.5:1, etc.). (c) There is a change in propeller size, blade number or material (I.e.: bronze to stainless)." This came from the 2012-2013 AWSA Tow Boat Policy Manual |
