Trailer Maintenance
I'm wondering what you guys do for trailer maintenance. Particularly, the wheel bearings. Sometime this past season, one of the trailer buddy bras came off one one of the wheels of my trailer, so the grease was exposed to water and such (not sure when it came off, but it was there at the start of the season). I've got a replacement coming, but how often do you guys replace wheel bearings/grease/etc., and are there any products you recommend?
The Bearing Buddy, if properly filled, is under a slight amount of pressure and won't let any water in if the dust cover falls off. Under the FAQ section on the Bearing Buddy website, they address the time and replacement interval. As long as you keep the grease filled properly, and you don't feel any amount of play with the axle jacked up and attempting to move the wheel in and out, or feel any roughness while turning the wheel, there isn't any real need to do anything. I always recommend that a good quality grease should be kept in the grease gun and used on everything. A guy doesn't go through so much grease that paying a few bucks extra for the better grease makes a difference.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
Each season I clean and repack the bearings on my '95 trailer. That little rubber cover on the bearing buddy is great for keeping dust and debris out of the mechanism. They can be purchased separately from the bearing buddy.
1995 Prostar 190 Remember, we must share our waters and be respectful of other boaters. Rude people suck!
I use http://www.mobiloil.com/USA-English/...ic_Grease.aspx Regarding the water intrusion, there's some that get's in depending on the temp of the hub and the temp of the water. Coming off the road and dropping in the water will cause a quick change in temp which will cause some water to get sucked in....hence the pressure on the bearing buddy mechanism. I trailer from Chicago to Kenora, Ont. every year 1400 miles round trip so I always inspect and repack. Don't forget your tires on the trailer maintenance - they need a good inspection as well if over 2 years old... I know a guy who can get you a deal on tires ![]()
I just laughed it off and bought new tires asap when I got it home. Glad it made it across town after the buy!
1991 ProStar / 351W with 1:1 Velvet Drive |
There you go...you learn something new every day. |
| Tags |
| mastercraft trailer |
