Fuel Sending Unit
I have a 1998 Prostar 190 and the fuel gauge may have to be replaced. The boat is in storage now so I can't match the sender up. Are there different part numbers (different gauges) or are they all the same? I would like to get one ready so I don't have to go shopping in the spring and waste time.
They are all not the same. I would call the guys over at Midwest MasterCraft in Crystal, MN and they should be able to hook you up. Good idea to plan ahead. If you are handy, you may just need to recalibrate your empty and full settings on your sender. This depends on the symptoms of your gauge. Either way the guys at Midwest MC can walk you through the diagnosis.
http://www.waterskis.com/ |
If it's the sending unit, you can fix it yourself pretty easily. There's a thread in the FAQ section about it. My 96 read full all the time, I followed the instructions, glued the magnets back in place and was done in about an hour and a half, including unbolting the tank and sliding it forward to get at it.
Try this plenty of info just google MC sending unit magnet
http://www.mastercraft.com/teamtalk/...ad.php?t=38453
99 MariStar 230 Sport LTR 330 |
I had trouble locating it again as well. Try this.
http://www.mastercraft.com/teamtalk/...ad.php?t=38453 |
I personally have not experienced the problem. I just bought the boat and will have to wait until next season to see exactly what the gauge says. The PO told me that he would fill it up and the gauge comes to half full. That makes me think possibly he used the 10% Ethanol and there may be some corrosion on the sender. My previous experience is with a sending unit in a Correctcraft that has a type of rheostat that can rust. I'm assuming that this is not the case with the units Matercraft uses. I will give the guys at Midwest Mastercraft a call.
Thanks for the replies. |
In this case, you can file a little off of the slots in the float that were binding and make sure it slides to the top without hanging up. I used a file that's just a little thicker than the board in the sender. If it lost one, or both magnets, you'll need to remove the sender, remove the round plate on the bottom and remove the float/magnet(s) that fell off. Position the magnet(s) in the float and turn the key ON, then slide the float from bottom to the top, making sure it reads correctly. You may need to reverse one of the magnets. Use Super Glue gel to keep it in place. |
#10
Do you happen to know the height of the tank in my 98?
I have an access hole in the transom, I may be able to get that thing out without having to remove the tank. |
