Starter needed for 77 S&S
Looking to find a reman starter for my "new" 1977 stars and stripes. Boat has a 351-rh rotation and is equipped with the Escort package. Not sure if that makes a difference??? Any links or part numbers would be helpful.
Also for question sake I see parts for PCM engines and such in Skidim but no Escort parts. Can these be interchanged? New to inboards so that may be a crazy question. Thanks! |
RH rotation? I would double check that, iirc it should be LH. As far as the 351w engine itself plenty of parts are interchangeable after all it's just a ford engine with the marinization items added later. Your on the right track with skidim they have a vast knowledge of inboards, although they can be a bit high on some parts.
James 1989 MasterCraft TriStar 190 SE Last edited by j.mccreight@hotmail.com; 11-23-2012 at 12:25 AM. |
Yes I don't know why I put rh but meant lh rotation. Thanks for the links. I am working up a Skidim order and will add the starter to my list.
Thanks! |
MC did put some RH engines in during the mid-late 70's, so I wouldnt necessarily dismiss the RH possibility based on what this forum thinks. Take a look at your engine/starter/prop and be sure!
RH would be reverse rotation and would require a CCW starter (LH = CW starter). If that is in fact what you need, they can be found new for <$150.
PCM 351w, 350hp |
I put an Arco starter in my '79 and would recommend it to anyone, a lot smaller but more powerful than original.
I am a fan of the Arco I put in my 81 as well
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
Arco makes both conventional and PMGR (permanent magnet gear reduction) starters. Theyre a brand, not a style.
PCM 351w, 350hp |
Thanks for the heads up on the Arco starter. That is what I am leaning towards unless I can something similar. There was an older Ford starter in pieces in the boat when I bought it. Been searching the net with the part number on the cap, but haven't been able to come up with anything. May not have been a marine starter in the first place....
#10
First you need to determine which rotation you need... but both conventional and PMGR starters are readily available for both rotations.
PCM 351w, 350hp |
