F/S Wet Sounds speakers / JL Audio HD900/5
Wet Sounds speakers / AMP JL Audio HD900/5 5 Channel Amplifier.
If interested best to call me 309-275-9090 as Im not on this site dailey. Sold my boat and pulled out my expensive Wetsounds and put back in the original system. I have 2 pair of Pro 8 speakers with mounts BLACK 2 pair white SW-650 & white Wet Sounds SW-10FA. All with the white saltwater series grills. JL Audio HD900/5 5 Channel Amplifier $595 Research this amp it is a Monster. white SW-650 (per pair) $195 Also have the the white Wet Sounds SW-10FA with white grill $175 All are Wet Sounds are Saltwater series but never anywhere close to salt water or even rain for that matter. Each cost me over $300 out the door just this past June. AMAZING SOUND! Pro 8 speakers with mounts BLACK $595 pair Prices plus just actual shipping from Peoria IL http://www.wetsounds.com/pages/products/SW-650.html http://www.wetsounds.com/pages/products/SW-10FA.html JL Main Channels @ 4 Ω 100 W RMS x 4 Main Channels @ 3 Ω 75 W RMS x 4 Main Channels @ 2 Ω 75 W RMS x 4 Main Channels @ 1.5 Ω 75 W RMS x 4 Main Channels - Bridged @ 8 Ω 200 W RMS x 2 Main Channels - Bridged @ 4 Ω 150 W RMS x 2 Subwoofer Channel @ 4 Ω 500 W RMS x 1 Subwoofer Channel @ 3 Ω 500 W RMS x 1 Subwoofer Channel @ 2 Ω 500 W RMS x 1 Subwoofer Channel @ 1.5 Ω 500 W RMS x 1 Frequency Response (Main Channels) 12 Hz - 28 kHz (+0, -1dB) Frequency Response (Subwoofer Channel) 12 Hz - 10 kHz (+0, -1dB) S/N Ratio, referred to highest rated power (Main Channels) >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth) S/N Ratio, referred to 1 W (Main Channels) >88.2 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth) Damping Factor @ 4 Ω >300 / 50 Hz Damping Factor @ 2 Ω >150 / 50 Hz THD+N @ Rated Power (Main Channels) <0.03% @ 4 Ω THD+N @ Rated Power (Subwoofer Channel) <0.05% @ 5 Ω Input Voltage Range @ RCA Inputs Switchable from 200 mV - 2 V RMS (Low) to 800 mV - 8 V RMS (High) Min Copper Power / Ground Wire Gauge Accepts up to 4 AWG wire Fuse Rating 60 A (AFS, AGU or MaxiFuse™) Filter Modes: Channels 1 & 2 (front) High-Pass only Filter Slope (dB/Octave): Channels 1 & 2 (front) 12 dB or 24 dB Filter Frequency Range: Channels 1 & 2 (front) 50-500 Hz Filter Modes: Channels 3 & 4 (rear) High-Pass only Filter Slope (dB/Octave): Channels 3 & 4 (rear) 12 dB or 24 dB Filter Frequency Range: Channels 3&4 50-500 Hz Filter Modes: Subwoofer Channel Low-Pass only Filter Slope (dB/Octave): Subwoofer Channel 12 dB or 24 dB Filter Frequency Range: Subwoofer Channel 50-500 Hz Detented, Calibrated Filter Freq. Potentiometers Yes Filters Defeatable? Yes Infrasonic Filter: Subwoofer Channel 30 Hz, Defeatable Remote Level Control Optional (HD-RLC) Remote Level Modes Sub Ch. only Channel Input Mode Switch Yes (2/4/6 ch.) Pass-Through Preamp Output None Source Channel Selection for PreOuts N/A specs 650'S 4 ohms All specifications are for each SW-650 RMS Watts: 100 PEAK Watts: 200 Frequency Response: 40Hz to 20Khz Sensitivity: 90db at 1watt / 1meter Mid Bass: 6.5 inch composite cone woofer with rubber surround. High Frequency: Coaxially mounted Titanium Tweeter * * * Size & Weight * Weight: (pair) 7.8 lbs (pair) (5.53 kg) * Sealed Box: N/A * Diameter: 6.8 inches w/grill (172.72mm) * Mounting Depth: 3.1 inches (78.74mm) * Hole Cut Out: 5.0 inches (127.00mm) * Note: Note: All specifications are for each XS-10FA Impedance: 4 ohms RMS Watts: 300 PEAK Watts: 600 Frequency Response: 20Hz to 500HZ Sensitivity: 88 db at 1watt/1 meter Size & Weight Box Specifications: Optimized for Infinite Baffle (Free Air) applications or .7 cu ft sealed enclosure. Weight: 8.1 lbs (3.67mm) Diameter: 11.02 inches w/grill (279.90mm) Mounting Depth: 4.72 inches (119.88mm) Hole Cut Out: 9.45 inches (240.03mm) Last edited by Dixie; 04-22-2013 at 12:34 PM. Reason: pics |
pics added
the SW-650s sold?
Sorry away for the Winter all for sale now
