Old 09-02-2012, 09:44 AM
lazyade lazyade is offline
Boat: '92 190 Prostar and the new project '05 X Star (Indmar 350 MCX)
Alternative ballast pumps?
I'm working on a bit of a restoration project on an '05 X Star - it looks like the ballast pumps haven't been looked after and need rebuilding (the internal magnets have snapped on all the pumps). Are there alternatives you can buy to the Jabsco ones?
In the interim is there any other way of draining the ballast tanks without the pumps working? (hoping to dump the extra 1,000 lbs of weight)!
Cheers... Adrian
'92 190 Prostar 260hp Indmar.
Last edited by lazyade; 09-02-2012 at 10:02 AM. Reason: add Q about emptying tankl
Old 09-02-2012, 09:51 AM
Also meant to ask, if I've pulled the electric motor apart, how do I get the damn bushes re-attached to the motor!
Old 09-04-2012, 06:51 PM
bcd bcd is offline
Boat: 93 Larson 200 SEI, 2002 X Star, 2012 X-2
Here's a thread that shows my trick for reassembling them:
http://www.mastercraft.com/teamtalk/...ad.php?t=42810
Old 02-01-2013, 12:59 PM
I should have done this update a number of months ago, but the post above worked brilliantly. We were able to reconstruct one pump (by gluing in the magnets and using the cotton trick to hold the bushes back). We put the repaired pump back in the boat and used it to drain the full tanks (damn that water smelt bad)! Just need to repair the other ones now. We did try the manufacturer for spares but it seems as though you can't buy spares for the motor, just the new impellers.
I think I'm right in saying you guys recommend the green impellers right? If so who manufacturers them, I don't think it's Jabsco (they seem to just list the two black ones).
Old 02-01-2013, 01:39 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
...I think I'm right in saying you guys recommend the green impellers right? If so who manufacturers them, I don't think it's Jabsco (they seem to just list the two black ones).
Yes, Green:
http://www.wakemakers.com/jabsco-bal...-impeller.html
Old 04-23-2013, 04:20 PM
dsword dsword is offline
You could try one of these if you are just looking to empty the ballast tanks while working on the boat.
http://www.jamestowndistributors.com...5746&SHOPZILLA
David Sword
Old 09-04-2012, 02:14 PM
XStar08's Avatar
XStar08 XStar08 is offline
Drainmastermarine.com?
Or you could go the way CC is/was going: one kind of bilge pump in the tank to empty, one somewhere outside to fill (but then you have to take into consideration that they are not selfpriming). However you would get rid of the impellers and would never have to care about having them run dry. On top you would get much faster fill/empty times.
XStar08
Old 09-04-2012, 02:24 PM
jfw432 jfw432 is offline
Boat: other
You can gravity drain the tanks if there is no obstruction. You could also dump them into the hull if you really have to. In addition to gravity draining, if your hose is hooked to the bottom of the hull and the line is open, the negative pressure from driving will forcefully suck the water out.
Old 09-04-2012, 02:27 PM
Thanks, however there's a light problem the boat is a bit of a project and not running right now (hence the desire to get the ballast water out) - see my other post under engines...
https://www.mastercraft.com/teamtalk...ad.php?t=50535
Having stripped down the Jabsco pumps they look like they've been under water too and are pretty corroded. We have however come up with an idea, attach a drill to the opposite end to the pump, and get the drill to do the turning - hopefully this will allow us to empty the ballast.
Old 09-05-2012, 11:07 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
Johnson makes some ignition protected pumps as well. You can get some really cheap non ignition protected ones from harbor freight for $30 or $40.
2003 X2
