Dash panels- 88 Prostar
The mount holes on my dash panels are cracking, so I figured I'd CAD up new ones and fab them. Right now, I've only got the left panel drawn out, I'll have the right side switch panel done early next week. I have a laser cutter in my classroom, and will make a trial set out of plastic, but I might have nicer ones done out of sheet metal and powder coated, depending on cost.
Top two holes are 2" in diameter, I have a depth gauge and hour meter there, the lower holes are for horn (left) and ignition key (right). The switch panel will be a copy of the original. I'm thinking for the switch labels, I might see if I can have vinyl letters cut, rather than trying to mess with silk-screening. (Possible to do on metal, but adds to cost.) Once I get them done, I'll start a thread in 'For Sale' if anyone's interested in buying a set. G Last edited by gweaver; 05-25-2012 at 09:00 PM. Reason: modify image coding |
As long as it's Lexan, they won't crack.
Anything less will crumble. Hint - LED Last edited by Philscbx; 05-26-2012 at 10:51 AM. |
The laser cutter will cut anything combustable. It's not too happy with some plastics, because of the particulate matter that comes off- I was leaning towards black lexan, so it looks factory. Wouldn't be too hard to do something translucent instead, with LED backlighting.
![]() G |
Paper prototypes cut- assuming they fit well, I'll have plastic pieces cut Friday.
![]() Then it's just a matter of getting vinyl letters for labeling the switches. Last edited by gweaver; 05-29-2012 at 10:53 PM. |
Tried something new for a prototype- got some engraving stock- black with a white underlayer. By setting line colors in the drawing and changing power settings on the laser cutter, I can cut through the panel on the black lines while only etching the blue text. Etching allows me to burn away the black plastic, exposing the white underneath.
I still want to play around with aligning the text for the switches, but I really like how these are looking. I made a practice panel with a plain font, then found the Hemi-Head font. I forgot to take a picture of the actual panel, so I couldn't label the various reset buttons. I'll correct that tomorrow and run another set of panels (hopefully the final set). ![]() A little more playing around and I should have something that's a pretty reasonable replica of the original panel, but with a few personal touches. G |
Are you going to possibly make a few sets for sale? I would definatly be interested in a set.
James 1989 MasterCraft TriStar 190 SE |
I would quite possibly be interested in this. I have a 1990 Prostar that Im restoring, and I need to replace these panels. The arrangement I have is different for the left panel. I dont have a depth gauge, although I kinda want to install one. But I also do have a safety switch there.
Here's what it looks like: ![]() I would like what you have designed above with a cut out for the safety switch also. But I would like the panel to be black with white lettering. Is that possible? PM me with more info please. |
![]() I am in need of one just like this as well... Mine is a 1990.... Key side only.... I will PM you as well.... |
Thanks for the interest. I'll certainly make extra sets if people want to buy some.
nkorep2: I can do custom plates as well, but I'd need measurements for the cut-outs and a layout. (pm sent) The image in my previous post shows blue text- that's just part of the drawing software. The coloring of the final pieces would look like the image below- a black plate with white text. The one below was made before I found the HemiHead font, but you get the general idea of what the final piece would look like. FWIW, I haven't done a cut on plastic with the HemiHead font, so when I get that done, I'll be able to show exactly what the final will look like. G |
#10
looks great, keep us posted, my '89 will be needing some tlc soon!
Jack ----------------------------------------- 1989 ProStar 190 Power Slot Somewhere between SML and LKG |
