Drivers Seat Removal 1993 ProStar
Hello all,
I recently removed my drivers seat in my "new to me" 1993 ProStar 190. I found a few helpful hints on he boards here, but figured I'm summarize what I did for anyone down the road that might be looking for info. My drivers seat was hard to adjust, which was the reason I wanted to work on it. The seat is connected to a pair of sliding rails that screw into the floor mounting rails. I removed the seat and the rails as an entire unit. I read some folks that could just slide the seat right off the rails, but I think that is only possible if the rails had been removed in the past and some internal rail locking components removed. What I did was: 1. Remove seat cushion and back cushion. 2. Slide seat all the way back and that will expose the front rail mounting screws on each of the rails. Remove each screw. Note: Mine were quite tight and I used a impact driver with a philips head bit to remove them. You might need the same or a big & stout philips screwdriver to remove them. Don't strip the heads!!! 3. On the seat, you will see several holes that can be used as access holes to the rear mounting rails screws. Slide the seat back until the access holes line up over the rail mounting screws. Remove two two screws. 4. The entire seat and rails can now be lifed out as a unit. I carefully sprayed some de-greaser into the rails and worked them back and forth to clean out some of the old sticky grease. I then worked a small amount of new grease into the rails. On one of my rails, two small metallic cylinders fell out and I think these were part of the locking mechanism that keeps the rails from sliding fully apart from one another. So one of my rails can come apart, and the other cannot. I didn't worry too much about trying to put it back together. It works fine. I also took the opportunity to clean off some rust where the metal rails meet the carpet. Also, now is a good time to clean and condition the vinyl on the right side of the seat and around the speaker to the right of the seat where access is difficult when th seat is in place. Put things back together in reverse order and you should be good to go. Good luck! |
Now u need to go get a swivel mount and put it between the slides and the seat base . I do not have a bolster seat , so this will raise the seat up maybe 2 inches , not much more than sitting on a cushion ( what most of us do anyway ) The swivel allows u to spin around to get out of the drivers seat when u get up , and also when sitting around and just hanging out u can spin around and be involved in the conversation instead of sitting straight forward all the time like a child in time out . One of the best things I have done to the prostar that I really think mastercraft should have done from the factory ..! ![]() |
did anyone ever conclude whether a swivel would work on a PS 190?
Would like to know as well...
1991 PROSTAR 190 Flagship Blue POWERSLOT OJ XMP CNC 13.7x17.5 .110 4B A.K.A. One of a kind mistake 2011 Southern Owners Best In Show- 1987-2000 class Trying to keep slalom alive Need Parts or Services? Call BAWS 813-996-2297 Need a new prop to fit you needs? Call OJ PROPS 800-359-9730 |
yeah looks pretty tight on my 94 205. won't be able to swivel much but I do like the idea of raising the seat as I hate sitting on a cushion
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
Item # 75631 Key Features Heavy-duty steel construction 6.25" x 6.25" x .75" thick Our Price $12.99 Low Price Guarantee Availability: Back ordered Expected back in stock 05/22/2012 Last edited by atlfootr; 05-10-2012 at 03:43 PM. |
Walmart will have them for about 12 to 15 bucks , and they are black powder coated . If they dont have them any boat supply place should have them . Very easy to find ..
#10
I really like that swivel idea, but I'm picturing the right side of my seat and quite a bit of that right seat area is in physical contact with the vinyl padding under the throttle control unit. Unless I moved the seat a bit to the left, I'm not sure if the seat would have room to rotate....
| Tags |
| seat, seat rails, seat removal |
