Old 03-06-2012, 05:41 PM
kevinkp1 kevinkp1 is offline
Boat: 2000 Prostar 190
Instruments For 2000 Pro Star 190
I have none of my instruments (gauges) working and have no idea where to start to get them functional. I am sure they need to be replaced, but cannot locate any. Any hints or assistance would be greatly appreciated.
Old 03-06-2012, 06:22 PM
j.mccreight@hotmail.com j.mccreight@hotmail.com is offline
Have you tried a mastercraft dealer, I'm sure they can get it fixed...
James
Old 03-06-2012, 09:28 PM
fskof's Avatar
fskof fskof is offline
Boat: 2003 Prostar 209 MCX
I would start off by checking the fuses. They should be under the dash. Check your owners manual for the exact location
Old 03-12-2012, 11:07 PM
Thanks
Thanks for responding fskof and j.mccreight. I have tried both suggestions to no avail. The dealer says the gauges are no longer available and power is present so fuses are good. I was wondering if anyone knows what gauges can be used to replace the originals that will work, or is there yet another option?
Old 03-12-2012, 11:49 PM
Greatlakesskipper.com has replacement mc gauges, I'd call them and see if they can match some up.
James
Old 03-13-2012, 07:05 AM
bturner2's Avatar
bturner2 bturner2 is offline
Does your boat have an MDC? Not sure when they switched over to the managed gauge system but having every gauge go bad at one time would seem strange. When did they go bad? Did it happen all at once? If this started all at once or when you just put the boat in service for the year I'd be checking connections. Almost sounds like you're missing a ground for the gauge cluster (most likely at the battery). Or if you do have an MDC this is a classic MDC issue.
Another way to go at it would be to pick one end and work from there. Pick an easy gauge to work on like the temp gauge and check for resistance at the sending unit. Trace the wire from the sending unit to the gauge and check for continuity on the wires. Then check the resistance on the gauge.
Another thing to try if these are not MDC controlled gauges is to pop one of the gauges out of the dash and connect it directly to the sending unit and see if it works then. That would eliminate the wiring. Hard to believe every gauge went bad though.
190 dash, 2000 mastercraft, gauges
