Old 07-20-2010, 04:56 PM
canuckwest canuckwest is offline
Boat: Prostar, 190, 1994, 350,
no fuel to fuel pump
I have a 1994 Mastercraft 190 with 350. with throttle body and injectors. Last weekend I replaced the water/gas canister filter. and since, haven't been able to get any fuel coming thru to the engine. on the engine side of fuel pump, it's spitting air when I turn on the engine and it cycles up. but never gets fuel. tried cycling it thru many times. and never any fuel. in fact, not getting fuel into the water/gas canister which would be the first point it should appear. I did spin it back off and filled with gas. but suspect I should have done this in the first place. now I think I have a line full of air and not sure how to fix the problem.?? any thoughts?
Old 07-20-2010, 05:01 PM
95prostar 95prostar is offline
Boat: 1995 prostar 190 lt1 powerslot
those canister filters have an inlet and outlet. is it possible you have it in backwards?
Old 07-20-2010, 05:39 PM
jimmer2880 jimmer2880 is offline
Boat: 95 PS 190 EFI
Send a message via AIM to jimmer2880
Some of the fuel tanks have an anti-siphon ball on the hose, where it leaves the tank. I've heard of these causing problems when doing fuel work. You may want to check there.
Also - some canisters have a bleeder button/screw on the bottom. Have you tried that?
If one day you're asked:
" How did you spend your time here on Earth?"
Will you say:
"I kept a crabgrass free lawn"
It's time to SKI.
Old 07-20-2010, 05:40 PM
Boat: 95 PS 190 EFI
Also, To get fuel from your canister to the pump, put some gas into an empty, clean mustard bottle. Take off your spark arrestor and pour a little gas directly down the carb. You will need to run it like this for a little while, until the fuel makes its way to the pump.
Will you say:
It's time to SKI.
Old 07-20-2010, 07:05 PM
thanks for ideas
no chance of inlet/outlet being mixed up. the canister is a simple screw off/on, like an oil filter. didn't touch the existing inlet/outlet hoses. and there's no bleeder button either on the canister or anywhere else along the way.
will check the other suggestions made when I get up to the lake again this weekend.
Old 07-21-2010, 08:31 PM
Footin's Avatar
Footin Footin is offline
Boat: 1994 Prostar 205, previously owned 1991 Barefoot 200, 1987 Prostar 190
Do this, it should work.
OH-IO!
Old 07-20-2010, 07:24 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Did you fill up the canister with fuel before installing it?
Bailey
'02 X-9
Lake Blue Ridge
Old 07-21-2010, 07:48 PM
fuel filter
no, I didn't fill the filter first...seemed to be 2 different opinions on that. I've since gone back and filled the filter. bit late tho' and it appears that there's some kind of air bubble blocking the flow?
Old 07-21-2010, 09:40 PM
Prime the separator. If you don't, it's like the biggest case of vapor lock possible. When the old canister comes off, the gas drains from both directions and it needs to be filled. If you have a TBI motor, drizzle some gas into the throttle body and start it. The pump will draw gas faster this way. Cranking it for a long time just wears down the battery and heats up the starter.
fuel, fuel pump, water gas filter
