Old 05-03-2010, 08:02 PM
[email protected] 450hp@bellsouth.net is offline
Boat: Mastercraft, Prostar 205v, 2000, Zero Flex Tower
Question Volt Gauge
Hey All,
Have not been on TT much the last several months. Volt gauge suddenly went to zero last weekend. Made it back just fine but the battery is new this year. Am travelling and have not had a chance to check the alternator. Any intial suspicians on whether the alternator, cables, or gauge are the most likely culprit?
I have been searching the forums but was unable to find an answer.
Thanks in advance.
Barry - 2000 Prostar 205V. Zero Flex Tower.
Old 05-03-2010, 10:44 PM
CiscoStu's Avatar
CiscoStu CiscoStu is offline
Boat: 2006 X-30, MCX
I would suspect that it's a bad ground on the gauge somewhere... It's the simplest gauge, it just reads the hot vs ground, that's it. If it went to zero and the boat still ran, it's not the battery. If your alternator (or regulator) were bad, you would slowly see the volt gauge go down to zero. When it gets below about 5v, you would notice that it's not running properly, especially at idle.
Did you try to start it again when you were back at the ramp? That's a good way to tell - if there's enough juice to crank it over, you know it's either a gauge ground or the gauge itself.
Old 05-04-2010, 09:23 AM
thank you
Stu,
Thanks so much for the prompt reply. If ever in Atlanta let me know as I owe you a pull!
Old 05-04-2010, 09:07 PM
CiscoStu's Avatar
Happy to help (or at least offer my two cents...)
If I ever have the chance, I'll take you up on that offer for sure!
electrical, gauge, voltage
