Old 08-01-2009, 11:38 AM
NoSubstitute's Avatar
NoSubstitute NoSubstitute is offline
Boat: 2008 Mastercraft X-2
Sheared Driveshaft on X10
Anyone ever seen anything like this? We were tubing the kids for about 30 minutes when on we idled back to pick up a tuber, and felt the boat vibrating a bit. We took off again, and felt major vibration, so I stopped immediately. But the boat into reverse, thinking we might have picked up some seaweed. Went forward again idling, and then a load clunk. No forward motion. Got towed back to the dock, put the X10 on the trailer, and couldn't believe me eyes. Prop had slide back into rudder. We don't recall hitting anything. The shaft looks straight. No dents or dings in the prop or the rudder. Any ideas?
Old 08-01-2009, 11:47 AM
Jim@BAWS's Avatar
[email protected] Jim@BAWS is offline
Boat: 1996 PS 190 LT-1/Powerslot
Bad alignment !!!
Purchse NEW driveshaft
get PROP refurbed
Check the bushings in the strut
Install
Alighn
That easy
[email protected]
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 08-01-2009, 11:49 AM
It needs to have the motor and strut alignment checked. If it's misaligned by too much, the stress at the point where the shaft enters the strut will cause fatigue. Remove the prop and look at the plastic in the strut bearing- it will be much thinner in one area.
Old 08-01-2009, 12:09 PM
munkymush munkymush is offline
Boat: mastercraft x2 2004 mcx
is it my eyes or is the strut badly bent in the second picture.. it looks bent to the left to me ?
Old 08-01-2009, 12:17 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
I agree, and if the strut was bent from a previous collision with something, that could be the reason for the shaft break
I'd like to see a straight on picture from behind the rudder forward, with the rudder straight ahead and see how much if any the strut/shaft is offset to the right of the rudder.
Charter Member Number 1
Quote: 2RLAKE,
Old 08-01-2009, 12:48 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
The strut is clearly bent over to the left. Needs a new shaft and strut, plug alignment and prop rebuild. Rudder may need to be dressed up too.
'04 MariStar 230VRS/MCX
Old 08-01-2009, 02:13 PM
Looking straight on from the back, you're right, it is definitely bent to the left. The strange part is the boat never vibrated until right before it snapped. How difficult is it to remove and replace the strut? Does the alignment have to be done at a dealer, or can it be done on a trailer/hoist?
Old 08-01-2009, 02:21 PM
TX.X-30 fan TX.X-30 fan is offline
Boat: mastercraft, X-30, 2004, MCX.
How does one grease the strut bearings??? And how often??
Must have gotten bent before and just was not noticed huh??
Old 08-01-2009, 05:05 PM
Head wound acting up again? Water is all the lube you need.
Old 08-01-2009, 05:35 PM
How did you know I was accidentally dropped a couple times as a child.
driveshaft
