Old 06-28-2009, 11:42 AM
hkallestad's Avatar
hkallestad hkallestad is offline
Boat: Prostar 190, 1989
Alternator squeeking a bit when starting up
The alternator on my PS190 1989 is squeeking a bit when starting up, and then goes quiet. I guess it's a bad bearing? Is it possible to change the bearing?
Old 06-29-2009, 12:12 AM
Bellinghamster's Avatar
Bellinghamster Bellinghamster is offline
Boat: 1978 Stars and Stripes, PCM 351 (60hrs)
Squeal on startup is usually due to a loose or glazed belt. The alternator pumps out full current for a short but trying to put back the charge that was used to crank the boat. Try tightening the belt, or if it is already tight, replace with a new one. The rubber gets less sticky as they get old.
Old 06-29-2009, 03:59 AM
hkallestad's Avatar
I have a new belt lying around, so I'll change it, only thing is that it doesnt sound like the belt tho.
Old 06-29-2009, 07:30 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
I agree, first/cheapest thing is to put on a new belt. Don't forget to check the pulley alignment. If it's still making the noise after the new belt, remove the alternator and see how it spins - take it to an automotive store and have them look at it. If it is a bad bearing, you'll need to replace the unit - no way AFAIK to replace the bearing.
'04 MariStar 230VRS/MCX
