Old 06-05-2009, 08:47 AM
CODY_YARBER07's Avatar
CODY_YARBER07 CODY_YARBER07 is offline
Boat: 1983 Mastercraft 19 Skiier Stars and Stripes
Send a message via MSN to CODY_YARBER07
Alternator Question
So, I bought a 140 amp Delco Marine alternator to run my stereo and the place that I bought it from (DB Electrical) explained to me which wires went where and I proceeded to install it. Once I got it installed I tested it and it is not charging. Not wanting to ruin my weekend on the lake I hook my old 30 amp alternator back up. It ran my stereo fine with no problems at all. I have two batteries isolated by a dual battery relay. The stereo includes 4 Polk Momo Speakers and a Polk Momo sub powered by a Sony Amp (250 watts RMS) AND 2 Wetsounds Pro 80's powered by a Cadence TXA3004 which sends about 300 watts to each Pro 80. Now I have no clue how much amperage this setup draws but like I said it has been working fine with the stock alternator. DB Electrical has offered me a replacement alternator or a full refund and I am leaning towards the refund if I can get by with my old alternator. Like I said, I ran it all weekend and it had no problem keeping charged. Just wondering what you all thought about it. Thanks so much, Cody.
1983 Mastercraft Stars and Stripes
351 With Powerslot
Old 06-05-2009, 09:09 AM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
Cody wish I could help you, I am in the same position, I have to upgrade my 55 amp alternator. I have read all of the past threads and have more questions now than answers. It seem like it is a bad alternator that they sent you. DB Electrical gets a lot of references on these type of web sites, so i would think that unfortunately you got a bad unit. If they are willing to pay for your shipping cost both ways, I would give them another try. My 2 cents worth.
Old 06-05-2009, 09:51 AM
JimN JimN is online now
ANY decent shop that does auto electrical repairs should be able to tell you what you need.
Old 06-05-2009, 10:21 AM
JimN, I was told by two local Marine rebuild shops that my alternator could not be rebuilt to a higher amperage. I thought that was weird, but i just got off of the phone with SKIDIM, they said the same thing.
Actually they said that for my 1996 190 w/ LT1 there are no after market alternator amperage upgrades or kits available to them. He said that they get a lot of calls about this problem w/ the early years LT1. I am waiting for a call back from Indmar about this. This has been a real interesting DIY job.
Old 06-05-2009, 12:49 PM
They're partially correct. That case can be rebuilt to about 75A and that's about it. Then, it needs to go up to the next size, which is easily available to them and that's what I just got for BriEOD- a 105A version. The next size up needs different brackets but if you want, I'll call the guy and ask what it will take to get up to 140A. He does them all the time and stocks most sizes, ready for rebuilding. Beyond stock parts, it becomes a bit of a custom job but really, anything can be made to work properly.
Old 06-05-2009, 02:46 PM
JimN, that would be great if you could hook me up with pricing / info about 105A version and the 140A version. Send me a PM about it,Thanks Patrick.
Old 06-05-2009, 06:21 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
I would think your current alternator is probably more in the range of 55A...
http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
Old 06-05-2009, 07:11 PM
Just after I posted last time, I called the shop to find out what the next size up can put out and he said about 165A. This case isn't exactly the same size but the brackets still fit. The span at the pivot is the same and it's a little deeper, larger diameter. This shop only rebuilds starters and alternators.
Old 06-05-2009, 09:49 AM
If the OEM alternator has only one wire and the new one needs an excite lead, which can be verified by looking at the diagram or calling the source, not having the excite lead connected will keep it from charging. This is needed because the old one (one wire) would have a permanent magnetic field and in the new ones, the magnetic field isn't created until the excite lead triggers energizing of the field coil.
Old 06-05-2009, 11:20 AM
TX.X-30 fan's Avatar
TX.X-30 fan TX.X-30 fan is offline
MC Platinum
Boat: mastercraft, X-30, 2004, MCX.
Good stuff JimN.
alternator, amplifier, battery, stereo, wetsounds
