Old 10-22-2008, 07:45 PM
Grover777's Avatar
Grover777 Grover777 is offline
Boat: 2001 PS 209
Replacing Blower Ducting
Hi:
While I was changing the oil filter on my 2001 PS209, I tore my blower duct (it runs right under it). The tear kept getting worse every time I touched it. I was going to use Tyvek tape to repair, but I have about a 6 inch area that is torn up and it is next to impossible to access the torn area.
How hard is it to run new blower ducting? It looks like I will need to remove a floor panel behind the motor box.
Any suggestions??
Thanks!!
2001 Prostar 209
1959 Glaspar Trident
Old 10-22-2008, 09:07 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Its not a bad job, but you might have to remove the panel behinf the motor box.
Some models have a hard pvc like tube that runs most of the way back that the flexible tube connects to. I am not sure about yours.
OH-IO!
Old 10-22-2008, 09:12 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
Simple, you put it back in just like you took the old out and the hose can be found at most any boat dealer and here, http://www.skidim.com/prodinfo.asp?number=MPI402-30000
Charter Member Number 1
Quote: 2RLAKE,
Old 10-22-2008, 09:14 PM
Grover777's Avatar
Boat: 2001 PS 209
I have not taken the ducting out yet.
How does the floor panel come out?
Thanks!!
2001 Prostar 209
Old 10-22-2008, 09:16 PM
Footin's Avatar
If it is like my 205, you take off the motor box then the six or so screws the hold down the panel. Lift it straight up and out.
OH-IO!
Old 10-22-2008, 09:42 PM
Chicago190's Avatar
Chicago190 Chicago190 is offline
Boat: Mastercraft, Prostar 190, 1996, 285 HP
If you look at the floor behind your motor box you will see that it is a section. Two ways to take it out. 1. Unscrew the hinges on the motor box and then there should be 4-6 screws which attach the floor to the boat. Lift out floor section. 2. Leave motor box attached and just undo the floor screw, and take out the floor and motor box as one section (two people may be needed for this approach.
On mine, I also had to remove the rear seat and also the vertical piece in front of the gas tank to get back far enough to remove the blower hose.
You could also do what I did for a season, which was to cut out the damaged section of blower hose and duct tape in a piece of expandable dryer vent hose to seal up the two sections.
1996 Prostar 190, 350 TBI and Powerslot
Old 10-22-2008, 09:49 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
To save a few bucks, head to a hardware or home supply store that carries RV stuff. In that department, you'll find the same size flex hose used in the RV world for waste water hook-ups. I bought one box (not sure how many feet were in it) for less than $10 and have enough left over in case I ever need another replacement.
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
Grover777's Avatar
Boat: 2001 PS 209
Are the screws holding the floor to the boat under the carpet?
2001 Prostar 209
Old 11-14-2008, 03:38 PM
94PS190's Avatar
94PS190 94PS190 is offline
Boat: 94, prostar 190, 96 prostar 190..anyone wanna buy one
I need to replace my duct this winter. If I remember right I need to remove the gas tank. Can anyone confirm this. My boat is a 94, 190.
Old 11-14-2008, 05:11 PM
MC Hero
Boat: Gone
Not necessarily, if you are going to pull out the old and it is still attached to the vent box, take it loose, tie a cord to the old, pull the old duct along with the cord from behind the gas tank thru the bilge underneath, then tie it to the new duct and pull up the new duct behind the gas tank with the cord and the tank won't need to be pulled.
