TeamTalk
-   Engine / Drive Train (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=24)
-   -   Spanner socket for ZF transmission (http://www.mastercraft.com/teamtalk/showthread.php?t=83334)
Vann 12-07-2017 11:29 AM
1 Attachment(s)
I'm looking for a speciality socket to torque down a retainer nut that goes on the output shaft of a ZF Hurth transmission.
I've made one as references in this thread http://www.mastercraft.com/teamtalk/...rchid=12051754
but it broke after about 20 ft/lbs and 89 is recommended.
I've checked all the stores here but being in Hawaii hurts. Does anyone e have one that they could ship me? I'd pay for all shipping and get it back ASAP.
FoggyNogginz 12-07-2017 11:45 AM
Have you considered calling a dealer on the west coast to see if you could potentially rent this tool from them? Just an idea.
mikeg205 12-07-2017 12:23 PM
I wonder if this is the same size....
https://guide.alibaba.com/shop/otc-t..._10042732.html
Vann 12-07-2017 12:45 PM
It's around 1 1/2 inches. I have the exact measurements at home but it's not a usual size for most spanner sockets.
curver900 12-07-2017 04:01 PM
if you have the diameter of the socket then I would go to my local big box and get the socket or a piece of pipe of the same diameter and make my own with a dremel, hacksaw and file or a grinder and make my own...
that looks similar to some 4wheel drive spanner sockets may have luck finding one for like a ford front end...
Dylan 12-07-2017 04:54 PM
I borrowed one from my dealer, and they had a hacked socket with some bar stock tack-welded on the outside..... but it worked!
Bouyhead 12-07-2017 08:02 PM
The retaining nut is a nyloc and should be replaced. You can buy the nut cheap and use it as a template to make your own socket.
CruisinGA 12-07-2017 08:42 PM
If you can weld or know someone who can this seems like the quickest/easiest route.
Use a smaller diameter socket with short pieces of bar stock on the outside sticking past the end of the socket.
Vann 12-08-2017 05:28 PM
1 Attachment(s)
Going to try and cut this craftsman socket to work. I hope I have enough Dremel blades.
waterlogged882 12-08-2017 05:43 PM
That may or may not take the torque.
Go to Harbor Freight and buy a hardened impact socket for an impact wrench.
