TeamTalk
-   Electrical (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=23)
-   -   perfect pass issues (http://www.mastercraft.com/teamtalk/showthread.php?t=62482)
JamesL 07-16-2014 12:02 PM
perfect pass issues
So the past two times I have gone out while wakeboarding with added ballast and perfect pass set my boat will vary speeds like crazy for a decent amount of time before leveling out and holding steady. Does not seem to have any issue when manually do speed when cruising. Even when turning with a rider being pulled and PP on it would act funny until you rode straight a few hundred yards. I have been told to check my paddle wheel which I did and it seems to be moving freely, i will spray some WD40 on it to keep it that way. Question is are there settings I need to adjust or something I am doing wrong? Its an 08 X45, Id like to avoid taking to the shop but sounds like it might be needed?
Thanks,
James
willyt 07-16-2014 12:30 PM
If someone could add instructions on how to modify the KDW, NN and CS settings on a Vdig that would be helpful too. we'll get this ironed out...
MattsCraft 07-16-2014 02:09 PM
1 Attachment(s)
You ask, I provide:D
JamesL 07-16-2014 03:48 PM
Thank you kind sir. Next round is on me
nemoflyer 07-16-2014 03:55 PM
MC Cruise control on KPH
How do I change the cruise back to MPH from KPH. It went to dealer for service before I bought it and now it is set to KPH and the temps are all in Celsius.
2006 X45
bturner2 07-16-2014 06:29 PM
It's in the base settings section of the owners manual.
JamesL 07-23-2014 07:39 AM
played with the KDW it was set at 90 and moved it to 200 since Im running with a few extra bags, moved NN from 50 to 80 I believe, and Cs from 650 to 700. Will post results next time I load it up, last night was just teaching first timers so no need for extra ballast or to be going that fast
