TeamTalk
-   Appearance (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=22)
-   -   Gel coat restorer (http://www.mastercraft.com/teamtalk/showthread.php?t=60718)
Hatch7 05-14-2014 03:20 PM
Gel coat restorer
Has anyone uses the 3m 1 step gel coat restorer with wax? It seems most have several steps but if it works, it could be worth the time saved.
damaged442 05-14-2014 03:40 PM
Yes I have used it. It was definitely an improvement. Like anything, do a test spot and see how it works for you. As far as wax protection, it didn't last very long, but it did do a decent job on the oxidation of the gel coat.
GoneBoatN 05-14-2014 03:55 PM
In the article -http://www.fiberglassics.com/restoration/restoring-gel-coat I found the comment:
Never use one-step cleaner waxes for the same reasons mentioned above, though to a much lesser degree. One step cleaner waxes use solvents to “clean” the surface and oils to provide a false gloss to the surface. When the wax in the product wears off, (which it will soon), the result will be similar to the scenario with Penetrol.
to be interesting. I have been using Meguiar's One Step Cleaner & Wax which might explain why I tend to have to wax several times a year.
Hatch7 05-14-2014 04:49 PM
Thanks guys. Sounds like it might save time in the short run but not in the long term. I had thought about turning it into a two step process and using a paste wax after step 1 but I think I'll look for another product. Any suggestions are welcome! Thanks again. Hatch
bochnak 05-14-2014 05:32 PM
Have any pics of what you are trying to bring back to life?
Hatch7 05-14-2014 06:02 PM
I don't have any current pictures. The boat is on the lift at the lake with the stern facing south. So that takes the brunt of the sun exposure. most of the boat is in good shape but the decals need to be replaced. I have them on hand just need to remove the old ones , deal with the stern, clean and wax. With the amount of hot GA sun hitting the rear of the boat there is a good bit of oxidation so I need to wax that section more often.
bochnak 05-14-2014 10:09 PM
Does it looks worse than mine:
Before:
http://www.mastercraft.com/teamtalk/...8&postcount=15
After:
http://www.mastercraft.com/teamtalk/...0&postcount=69
Rotary polisher with rubbing compound and wool pad should clean it up well. Use the 3m stripe off tool on electric drill and decals will be off in 1 hr.
Hatch7 05-14-2014 11:04 PM
WOW! That is amazing! I plan to use the 3m products - did you find a good wax? How did it come out after the automotive wax. Great pics btw. Where do you keep your boat?
blackhawk 05-15-2014 12:43 AM
1 step products never payoff or work like they claim. Do it the right way and take pride in it.
bochnak 05-15-2014 10:29 AM
Decals and wax go on this weekend after a bit more buffing. I will be using Collinite 885 paste wax. Get it on ebay for $18 a can.
Like others mentioned, don't use a 1 step product. The 3m products does not contain silicone, waxes, etc. to give you a nice look that eventually will fade.
Do a search, oxidation has been covered many times.
