TeamTalk
-   Appearance (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=22)
-   -   underwater lights no drilling (http://www.mastercraft.com/teamtalk/showthread.php?t=60241)
JamesL 04-23-2014 06:51 AM
2 Attachment(s)
So I wanted to install some underwater lights without drilling into the hull, this is what I came up with. I mounted two small plates that hang down from the swim platform and ran the wires through a water sealed cord grip and drain plug I made with some hard plastic. from there I mounted a terminal block on the inside of the boat on the plastic divider along side the engine then ran wires to an empty switch on the dash. I can take more pictures if anyone is interested
clrussell 04-23-2014 08:29 AM
Had it in the water yet?
JamesL 04-23-2014 08:35 AM
Plan on going out Friday after work
DonB 05-11-2014 05:44 PM
I don't quite understand where you ran the wires. Could you post a photo please. I like the lights, but don't want to drill holes in the hull.
FoggyNogginz 05-11-2014 06:16 PM
It looks like the wires are running through the custom drain plug that he made out of hard plastic, and sealed to be water tight. Nice idea.
JamesL 05-12-2014 06:37 AM
yes, they are ran through the drain plug. Ill grab some pictures tonight
DonB 05-12-2014 08:48 AM
Thanks
rydog 05-12-2014 10:24 AM
What LEDs did you use on yours?
dvsone79 05-18-2014 08:21 PM
1 Attachment(s)
You can get a drain plug LED from eBay for $50 shipped:http://pages.ebay.com/motors/link/?n...028759&alt=web
It is a 1/2 NPT" so I had to get an adapter to make it fit 3/4" NPT. I bought it a year ago and just got around to installing it. The seller may make one that fits a 3/4" NPT.
FoggyNogginz 05-18-2014 11:41 PM
Nice! Where did you run the power from? Splice into the transom light?
