TeamTalk
-   Trailers (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=27)
-   -   Reliable actuator electrical connection (http://www.mastercraft.com/teamtalk/showthread.php?t=58083)
MarkS 11-05-2013 11:48 AM
Please help? On my 2008 Xstar trailer the solenoid valve of the reliable actuator is connected to my left hand indicator. I would have thought it should be on an auxiliary line and go to the reverse lights of the car. Can anybody advise.
Table Rocker 11-05-2013 11:53 AM
It should go to the reverse lights on the tow vehicle.
Thinking about it more: If the solenoid works like mine (bypass when powered) you would have no brakes with it wired to the left turn light since it is hot when braking.
MarkS 11-05-2013 12:20 PM
Thanks, for your reply. I believe this is exactly what my problem has been. Do not understand who wired this girl.
Table Rocker 11-05-2013 12:50 PM
You would be much better off with the solenoid not wired than you were with it wired into the brake/turn light. Basically the only time you had brakes was when you were trying to back it!
