Ballast on X80
Has anyone installed additional ballast on a single screw X80 for surfing. If so, what set up did you use? Thanks
You might want to give the guys at International Fly High a call. They will most certainly know how to set your boat up for best results.
We just had a WakeMAKERS customer order a custom Enzo style surf sac for his MasterCraft X80 with the single motor. He will have it this week. I will try and get some pics to post. From my experience the X-80 is so giant you just need a couple ton's of ballast. Once you do dial it in, WOW.
You might also talk to the guys at SwtichBladeWake.com. I know they have designed a double switch blade for Mr. Strong, another one of our customers. The wave is outstanding. https://scontent-a-sea.xx.fbcdn.net/...76872508_n.jpg https://scontent-b-sea.xx.fbcdn.net/...56940344_n.jpg |
Custom sack
If you could get me the info on the custom sack, that would be great.
Thanks for the reply |
The bottom pic isn't an x80
Too bad, sweet curl
